I just replaced my pistons and rods in my B16 2nd gen, code #4. crank angle sensor. tried a different dist and same prob. Any suggestions?
i've got the same problem..
code 4 and the car won't rev over 3.5 K rpm...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr650 »</TD></TR><TR><TD CLASS="quote">check your timing<<<</TD></TR></TABLE>
what year car is that.
well, i marked my dizzy b4 i took it off.. so timing should be good.. i also rotated the crank several times and the cams are dead on..
Even swapped my bro's gsr dizzy too, and I still get the code 4..
this is really getting to me..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92HB_HB »</TD></TR><TR><TD CLASS="quote">Even swapped my bro's gsr dizzy too, and I still get the code 4...</TD></TR></TABLE>That kinda says it's the wiring from the distributor to the ECU. Remember the signal leads from the 3 sensors are shielded, at least for some years. So if anybody tried splicing things, check to see if the lead is shorted to the shield.
<U>UPDATE</U>
It turns out my ECU is F'ed up, NO good anymore..
I took my ECU and swapped it in my brothers gsr.. and got the same code 4.. when i put his ecu back in, there was no code.. THat right there proved to me that the ecu is fried..
This really sucks.. now i have to find me another ECU and rechipp it for hondata..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92HB_HB »</TD></TR><TR><TD CLASS="quote">It turns out my ECU is F'ed up, NO good anymore...
</TD></TR></TABLE>Just for grins, check out the harness sockets on the ECU. Just to rule out a bent or broken pin where the harness plugs in. Maybe you can fix something like that?
