HELP!!CEL code 7 and 23
Old Jul 10, 2003 | 08:20 PM
JdmEg6Hybrid's Avatar
Default HELP!!CEL code 7 and 23
how would i get rid of them? please help
thanks in advance
Old Jul 10, 2003 | 08:53 PM
orange.honda's Avatar
Default Re: HELP!!CEL code 7 and 23 (JdmEg6Hybrid)
well the code 7 is throtle position
and code 23 it knock sensor.
so you could fix the problem or you could just disconect the battery and they will go away. if you do just disconect the battery then they may come back. i suggest you fix them.
Old Jul 11, 2003 | 02:11 PM
Default Re: HELP!!CEL code 7 and 23 (orange.honda)
HOW WOULD I FIX THEM I'M NEW TO THE HYBRID
Old Jul 11, 2003 | 04:48 PM
bump, bump it up
Old Jul 11, 2003 | 09:02 PM
salbaje's Avatar
take the ecu fuse under the hood. if it still comes up see if the knock sensor is plugged in.
Old Jul 11, 2003 | 10:59 PM
irev210's Avatar
Default Re: HELP!!CEL code 7 and 23 (salbaje)
im guessing you didnt bother to hook up the knock sensor
and your TPS needs to be calibrated. Get a helms manual.
.45 volts at closed throttle
4.5+ volts at WOT.
terplaygroun_dc2
Oct 23, 2008 09:38 AM
davidu
23
Oct 15, 2008 06:30 PM
Jonzo
Jun 25, 2005 11:28 AM
99spanishGT
Mar 26, 2004 12:40 PM
roadawg
Feb 11, 2004 01:10 PM
