HELP! Can't Remove Intake Manifold Gasket!!
Old Jan 2, 2004 | 01:51 PM
turbotime's Avatar
Default HELP! Can't Remove Intake Manifold Gasket!!
Please help just took off my intake manifold and the gasket is not coming off, i got a few chunks off but other pieces are on their, solid. I've tried everything from scrapers to razors, please help?? Is there a solvent or something I can use to get it off or something?
Old Jan 2, 2004 | 02:08 PM
DOHCarp's Avatar
Default Re: HELP! Can't Remove Intake Manifold Gasket!! (turbotime)
Gasket remover....sold at all automotive stores. that helped me a little bit, but you still have to scrape alot.
Old Jan 2, 2004 | 02:24 PM
turbotime's Avatar
ok got it off but the store didnt have the gasket to replace it? Will this insta-gasket stuff work, says its good to 400 F
Old Jan 2, 2004 | 02:44 PM
turboxsi's Avatar
Default Re: (turbotime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote">ok got it off but the store didnt have the gasket to replace it? Will this insta-gasket stuff work, says its good to 400 F</TD></TR></TABLE>
I don't think it will work!
Just go to your local honda dealership, and drop 16 bucks or so (i just put my itr I/M on and that is around the cost of a new i/m from honda). You don't wanna go cheap on something like your I/M gasket, just stick with the OEM honda gasket.
Old Jan 2, 2004 | 03:04 PM
LudeyKrus's Avatar
If you don't have a gasket, and have to have the car running, the high-temp silicone will work on an intake manifold. I used it on a 240 and it worked fine. but REPLACE IT W/ A GASKET SOON! Don't be ghetto.....
Colombiano127
12
Jan 3, 2008 02:34 PM
zccr-xsi
10
Apr 24, 2006 04:26 PM
LSegHatchy
11
Mar 30, 2005 08:46 PM
253EK
Jun 10, 2004 10:16 PM
MR. MIYAGI
Mar 26, 2004 08:01 PM
