Help!!!! A broken LSD? k20a
Old Nov 20, 2004 | 01:32 PM
TypeR0186's Avatar
Default Help!!!! A broken LSD? k20a
https://honda-tech.com/zerothread?id=1061923
Modified by TypeR0186 at 10:06 PM 11/21/2004
Old Nov 20, 2004 | 02:16 PM
drdisco69's Avatar
Default Re: Help!!!! A broken LSD? k20a (TypeR0186)
Well if the car won't move then it seems like it's a good time to take the transmission apart and take a look.
Old Nov 21, 2004 | 11:37 AM
Denny Crane's Avatar
It seems like the axle stub could have sheared right at the end of the side gear splines. To transfer power to the driver side requires both spider and side gears plus the spider gear pin to be intact. Even if the LSD was toast, it would still be able to move the car just like a non- LSD diff would.
Since the axle stub end fits into the side gear splines but hasn't dropped out completely, this is my guess given the info you provided. This will likely be the case if you firmly grab the pass side inner CV and attempt to move it around. You'll likely detect some slop but the driver side will have no perceptible play. In other words, you're halfshaft is now about 1 1/2 inches shorter.
Old Nov 21, 2004 | 05:28 PM
TypeR0186's Avatar
Default Re: Help!!!! A broken LSD? k20a (hybrid2nr)
bump video is up... in link
Modified by TypeR0186 at 2:40 AM 11/22/2004
champLSinteg
May 24, 2007 08:11 AM
champLSinteg
May 22, 2007 11:38 AM
jep
Jun 12, 2006 02:55 PM
2bars
Dec 11, 2004 08:21 PM
servion
Jul 1, 2003 11:59 AM
