NEEEEED HELP
Old Sep 6, 2003 | 10:42 AM
durrett syndrome's Avatar
Default NEEEEED HELP
my friend has a b16 and i just changed the cams to 98 itr cams and we changed the timing belt also the car runs like **** but it idles fine very wierd. i checked the valves, timing is all tdc, grounds are good, and distributer timing is correct, what else could i possibly do i also too hose off of the fpr to raise fuel presure and still runs shitty. need help badly
Old Sep 6, 2003 | 06:37 PM
mr.beeks's Avatar
Default Re: NEEEEED HELP (durrett syndrome)
check your
sequence on your distributor
dont forget is
1-3
2-4
Old Sep 6, 2003 | 09:08 PM
i cant put the prongs on the distributer any othere way they then already are. so that has to be correct
Old Sep 6, 2003 | 09:11 PM
B00ST2nR's Avatar
Default Re: (durrett syndrome)
well... if you just slap some bigger cams on, it's not likely gonna run that great. You need to tune it. Makes a WORLD of a difference.
Old Sep 6, 2003 | 10:00 PM
salbaje's Avatar
try adj. fuel pressure reg
Old Sep 7, 2003 | 07:48 AM
ok i will try that thanks.. but i didnt think it woudl run that frikin bad with out fuel because it barely goes...
Old Sep 7, 2003 | 07:56 AM
jung4g's Avatar
Without the vacuum line to the FPR it won't be changing according to Vacuum, hook it back and see what happens... The extra fuel should be there under full throttle, close to what you'd be at now without the vacuum line. Go and get a B&M regulator, and gauge, this is a super simple mod that can help a lot in dialing in slight fuel changes...
Good luck...
Jung
lsvtec_hatchback
Mar 25, 2009 08:33 PM
killerpenguin21
Aug 7, 2008 11:16 AM
jrubenis
Jun 1, 2005 01:01 PM
blowme
May 17, 2005 04:48 PM
shingles
Feb 16, 2004 03:57 PM
