Help! B18c1 swap issues
Old Sep 9, 2009 | 01:33 PM
AVHONDA's Avatar
New User
Icon6 Help! B18c1 swap issues
I have just recently swapped a B18c1 into my 94 civic sedan. The motor was rebuilt with new everything. I tried to start the car up after putting it in and it bogs really bad. Sounds like no airflow. I haven't had issues like this in the past swaps i had done with GSR's. It also wont go past 3,000 rpm's. I checked all the wires and everything and it all seems to be where it should be. Anybody knows or has any ideas as to what it might be? please let me know. Thanks.
Old Sep 9, 2009 | 01:45 PM
8zero8's Avatar
Default Re: Help! B18c1 swap issues
distributor? battery?
Old Sep 9, 2009 | 01:49 PM
AVHONDA's Avatar
New User
It has a brand new distributor. i checked the spark plugs and replaced them. i had the valves retuned also. The battery is new also.
Old Sep 9, 2009 | 03:39 PM
8zero8's Avatar
ECU? tps? injectors? 02?
Old Sep 11, 2009 | 07:41 AM
AVHONDA's Avatar
New User
I checked everything you had mentioned. I checked the ecu as it was chipped to the motor. i tried my guys stock gsr ecu also and still didnt work. The tps sensor i made sure was plugged in. The injectors was replaced. the O2 sensor is plugged in. i checked everything.
Old Sep 11, 2009 | 12:43 PM
8zero8's Avatar
check if the alt is rechaarging the battery.
Old Sep 12, 2009 | 09:08 AM
abelkayn's Avatar
what harness are you using? if you noticed, the plug for the map and tps sensors are the same, sometimes you can plug them in to the wrong place, check to make sure if everything is plugged in to the right place. have you also checked for vaccuum leaks?
Old Sep 12, 2009 | 09:31 AM
b20vtechb's Avatar
sounds like limp mode.. make sure your using the right plug for your map. you car may have the map on the firewall so you'd have to use that plug not the one on the gsr harness. also you need to check for trouble codes. your purge solenoid and iat plugs could be swapped. but that would ruin your iat.
eggie75
Feb 26, 2017 09:34 AM
tweekdb17
Apr 4, 2009 02:45 PM
cvchb91
Nov 30, 2004 06:33 PM
Projekt20
Sep 6, 2002 11:12 PM
OneSunkCivic
Aug 29, 2002 02:56 PM
