Help - b16 valve springs in a b18b
Old Mar 28, 2004 | 07:18 PM
Sed8ed's Avatar
Default Help - b16 valve springs in a b18b
I am finally back to installing some left over b16 valve springs in my gf's LS and we came into a problem (or two). (note I had previously been told this would work)
Problem 1:
-The LS keepers are larger that the b16 keepers and dont fit into the b16 retainers
-New keepers are $4.12 each and I need 32 of them
Problem 2:
-LS keepers are physically smaller in diameter than b16 keepers plus they don't have a proper second step for the inner springs (they are somewhat tapered on the step face
Suggestions? I had installed ITR valve springs in my civic (LS engine as well) but before had installed the engine in my hatch I got a really good deal on a full crower setup so I never ran the engine on those springs, I had used the ls retainers at that time without really examining them.
I am also a little concerned with the gap between the side of the spring and the wall of the head but it looks like it will clear. (checked helms, it's within tolerance)
I have read all other posts on here to try and find any solutions but all I can find is that they arn't compatable, however like I said, they seem to be within size tolerance... I did notice that people have tried putting b16a inner springs into the b18b springs and was wondering about doing this on both the intake and exhaust but will that make the exhaust side too stiff in comparison to the intake? any further help on fixing this little hiccup would be greatly appreciated.
Old Mar 28, 2004 | 07:30 PM
AngelTeg's Avatar
Default Re: Help - b16 valve springs in a b18b (Sed8ed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sed8ed &raquo;</TD></TR><TR><TD CLASS="quote">I am finally back to installing some left over b16 valve springs in my gf's LS and we came into a problem (or two). (note I had previously been told this would work)
Problem 1:
Problem 2:
YEs, the vtec keepers and the non vtec keepers are different... you need a new set of keepers.
Problem 2... I'm assuming that you're actually talking about the retainers. if you know a good machine shop, I bet they can machine downa flat surface to hold the inner valve spring, personally, I wouldnt do it... just find a set of B16 retainers. If worse comes to worse, I have a few sets of B16 retainers...
-Mike
Old Mar 28, 2004 | 07:56 PM
Sed8ed's Avatar
Default Re: Help - b16 valve springs in a b18b (AngelTeg)
I have the B16 retainers too but the problem was with the keepers... I was wondering about using the LS retainers and keepers on the b16 springs because of the extrordinary cost of the B16 keepers.
Has anyone tried using (not installing but actually running) B16 inner springs with B18b outer springs? Also will b16 inner springs on the B18b exhaust side be too stiff?
Old Mar 29, 2004 | 07:05 AM
Sed8ed's Avatar
anyone else?
ttt
Old Mar 29, 2004 | 10:45 PM
Sed8ed's Avatar
Bump... help, I really want to get this head assembled
Old May 18, 2010 | 09:52 PM
rmunoz2's Avatar
I know this is old, but couldn't find anything else on this subject. Did u ever get the answer to your last question regarding the b16 inner valve spring and b18b Outer intake spring? I am cleaning the head up while its off and have b16. Inner valve springs just layin here.
Old May 19, 2010 | 10:47 AM
siregcivic's Avatar
good job fukin newbie bringing back a 6 year old thread that probably wont answer your question
Old May 19, 2010 | 11:03 AM
rmunoz2's Avatar
Rather than knockin it, why not answer it? If u can. Plus I was bored, seen em on the shelf and said hey I wonder...
Im guessing it hasn't been answered because no one has tried it. Is this true?
Old May 19, 2010 | 12:38 PM
rmunoz2's Avatar
I found the answer to my own question finally. There was one thread with the answer to this question, and the answer is no.
Guess I have to take them out, oh well The car did start, run pretty smooth and all but it had no power under load and without it.
ThatOneGuy96
Engine Machining & Assembly
10
Jan 28, 2021 05:27 PM
k_boi_EF
Jan 11, 2009 10:15 PM
EF-XLR8
Jul 5, 2005 12:24 AM
NA_geezer96
Mar 18, 2004 08:32 PM
1BadDC2
Jan 25, 2004 06:42 PM
