HELP ASAP on Swap??
Old Apr 22, 2007 | 02:52 PM
Slow-EJ8-4Now's Avatar
Default Need help...motor won't start after swap????
i just swapped a new motor into my 96 dx coupe and i'm not getting any spark nither am i getting any fuel through the line. is there any fuses that i should check. Do you guys have any idea what the problem might be.
i really need help
thank you
Modified by Slow-EJ8-4Now at 9:35 AM 4/23/2007
Old Apr 23, 2007 | 08:36 AM
Default Re: Need help...motor won't start after swap???? (Slow-EJ8-4Now)
noone has any ideas of what the problem might be???
Old Apr 28, 2007 | 08:18 AM
shauniewalnuts's Avatar
ecu plugged in? ecu fuse?
Old Apr 28, 2007 | 02:38 PM
slvrcvc93's Avatar
First check grounds 2nd check ecu third fuses then main relay
brasiliangee90
Apr 25, 2008 11:40 AM
DSMDude
Nov 24, 2004 04:24 AM
SOHCVTECx2
Aug 2, 2004 09:53 PM
T25 civic
Nov 20, 2002 03:46 AM
Metal_SOL
15
Sep 9, 2002 09:41 PM
