help 97 hatch
Old May 9, 2006 | 07:34 AM
existanzcivicb20's Avatar
Default help 97 hatch
hey guys I have a 97 hatch with a b20 obd2 and the problem is this when im driving every thing
is fine but when im coming to a stop and throw it in neutral the idle stay at 2000 rpm then when
the car come to a complete stop the idle goes back to normal but only when I am completely
stoped why is this
Old May 9, 2006 | 09:23 AM
devnull's Avatar
Either you have a vacuum leak or you have an air bubble in your coolant system. Or you have a bad EACV.
Default Re: help 97 hatch (existanzcivicb20)
has any one had a similar problem to this I just want some were to start looking
Old May 9, 2006 | 09:28 AM
Default Re: (devnull)
if it was a vacuum leak wouldn't the idle stay high and the air bubble in my coolant wouldn't that cause me to over heat but thanks and ill check everything 2night just trying to get things rit but thanks
Old May 9, 2006 | 09:45 AM
devnull's Avatar
Air bubble would not cause you to overheat.
Old May 9, 2006 | 10:02 AM
ok well ill be sure to check that wen I get home
Old May 9, 2006 | 10:58 AM
Default Re: (existanzcivicb20)
how do you check if you have a bad EACV
honcrf150
13
May 29, 2012 10:28 AM
happy123
May 21, 2009 03:11 PM
oem_CD5
13
Mar 14, 2007 07:15 PM
existanzcivicb20
May 16, 2006 03:40 PM
existanzcivicb20
May 9, 2006 01:37 PM
