Help??
Old Jul 16, 2002 | 07:26 PM
Soku1kcivic's Avatar
Default Help??
I have D16Y8 that has a blown bottom block and I have a D16Y7 complete working condition and I want to swap the VTEC head onto the D16Y7 non VTEC. can anyone please put all the info so that i can do the swap.
Thanks
Old Jul 16, 2002 | 07:33 PM
kinesistech's Avatar
Default Re: Help?? (Soku1kcivic)
You need a new head gasket, and intake gastket. The head will bolt right up with no other mods. You may need a vtec controler.
If your car has the y7 it has a 3 wire iac valve. You will either need to convert your wire harness, ecu, and intake manifold to the y8 or you can use your stock manifold, ecu and a vtec controller. The y8 automatic manifold has bigger runners and still uses the 3 wire iac if you want that one.
If your car was equipped with the y8 then just use the y7 block only, everything else is the same.
Old Jul 17, 2002 | 12:21 PM
Default Re: Help?? (kinesistech)
Hey what about the TDC,Pulley,CAm gear ??
Thanks
Old Jul 17, 2002 | 12:32 PM
Everything else is the same.
96ferio
22
Apr 22, 2014 04:25 AM
raider1qaz
49
Mar 3, 2014 09:53 AM
pnwjdm
Sep 23, 2013 07:34 AM
85_305
47
Dec 28, 2006 02:45 PM
phasewest
Dec 12, 2004 08:57 PM
