heat guard removal - bad idea?
Old Jul 11, 2005 | 04:40 AM
run-it-red's Avatar
Default heat guard removal - bad idea?
My heat guard hangs lower than my pet hampster's IQ. It scrapes on EVERYTHING. I want to take it off.
What are the cons for removing it? Or should I leave it be?
BTW, I have a 98 ek with stock header.
Old Jul 11, 2005 | 06:01 AM
One2chi's Avatar
Default Re: heat guard removal - bad idea? (run-it-red)
if you cant bend it up to where it doewsnt scrape, by banging or some other means, then by all means rip the bitch off, you might experience slightly higher engine compartment temps, but not enough to worry abotu unless you alreayd ahve an overheating problem....other than that...nothing....jst be sure your exhaust manifold doesnt scrape then...or after a while youll be dealign with a nasty exahust leak.
Old Jul 11, 2005 | 07:33 PM
run-it-red's Avatar
Default Re: heat guard removal - bad idea? (One2chi)
Thanks for the input. Wouldn't mind hearing from a few more people, though...
Old Jul 12, 2005 | 10:00 AM
JDAMC's Avatar
I pulled all my heat guards. Rattling bastards!
Old Jul 12, 2005 | 06:09 PM
run-it-red's Avatar
Default Re: heat guard removal - bad idea? (JDAMC)
Haha...
Any opinions, though?
Old Jul 14, 2005 | 12:00 PM
run-it-red's Avatar
I can't believe that only 1 guy in the WHOLE of h-t knows something about heat guards!
Old Jul 14, 2005 | 04:25 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
I took all mine off except for the one covering the cat. No issues here.
Old Jul 14, 2005 | 04:41 PM
bosco500's Avatar
Take it off. All it will do is harden the sound deadening material under your carpet.
otgarza
Honda CR-V & Element
Dec 4, 2012 03:52 PM
8YourV8
17
Dec 31, 2010 04:14 PM
DC4 Rasta
Feb 1, 2006 09:41 AM
LSEGHATCH
Aug 23, 2005 07:42 AM
