Headgaskets
Old Jun 15, 2003 | 07:50 PM
OVRsi's Avatar
Default Headgaskets
For example: the mugen 2ply headgasket, which a (typeR?) compression from 11.1 to 11.4. Does applying a new part such as this instantly increase power because of the compression? Im still learning how an all- motor setup works and evolves. What exactly would this gasket do if placed on a pretty stock motor? thanks, jake
Old Jun 15, 2003 | 07:53 PM
poison's Avatar
Default Re: Headgaskets (OVRsi)
It will up the compression about .4 or .5, and on any motor, when the compression is raised, it will create more of a push down on the piston when the mixture is burned, thus creating more power.
With a thinner headgasket, the head is just slightly closer to the block, being less combustion chamber volume, and more compression.
HTH.
Accord CVCC
Apr 7, 2006 12:34 PM
MNsnowdaboy
Jul 23, 2004 04:53 PM
MNsnowdaboy
Jul 22, 2004 08:59 PM
nd8ch
Feb 26, 2003 08:10 PM
