I'm right because I'm right, not just because I have plenty of experience. I let me advice do my talking.
I've worked for Honda/Acura shops for many years now but I don't think I need to prove my credentials. It shows.
Also, you're still wrong. You've done nothing to prove your credentials.
LoL riiiiiiight. Originally Posted by holmesnmanny
I'm right because I'm right, not just because I have plenty of experience. I let me advice do my talking. I've worked for Honda/Acura shops for many years now but I don't think I need to prove my credentials. It shows.
Which shop have you worked for?
Originally Posted by DCFIVER
LoL riiiiiiight. Which shop have you worked for?
Quote:
Btw, you're still wrong.
Guys. I know you're trying to help, but please return your focus to the OP rather than on each other.Originally Posted by holmesnmanny
I don't feed the trolls. Sorry. Btw, you're still wrong.
thnx ronj
its only confusing me more....
Car runs fine now
no presure into the plastic tank
no coolant lost.
nothing is wet in the bay
car idles fine
hoses are normal not exploding
headgasket doesnt leak in the corners like the previos gasket
ticking sound is gone
temp stays normal
but still bubbles in the rad while i bleed it for 2 hours
changed the rad but stil having bubbles.
i drive around while the rad is bubbeling
Car runs fine now
no coolant lost.
car idles fine
temp stays normal
The water pump is going to pump the coolant out of the radiator. Thats normal.
You need to compression test to see if there is actually a sealing issue.
Sorry. Everything I have stated is a fact and can probably be found by just a little bit of research,via the net, on your part.Any other advice given regarding head gasket failure is garbage.Plain and simple.Originally Posted by joytjuhhhh
thnx ronjits only confusing me more....
Quote:
Do you mean while you are driving or when you pull over you can hear it bubbling?Originally Posted by joytjuhhhh
Does coolant flow out of the overflow bottle?
