Header
Old Aug 22, 2002 | 03:37 PM
alilboi504's Avatar
Default Header
My header has a crack in it. Is it ok if i still drive wit it?
Old Aug 22, 2002 | 04:02 PM
91f22's Avatar
Default Re: Header (alilboi504)
it is fine for a little while depending on where the crack is. If you drive too long on it and too hard you are going to burn exhaust valves ifthe crack is near the head because the reversion of an exhaust stroke and overlap causes fresh air to enter the header and if it is near the head it could cause the valve to heat up excessivly and burn.....or if it is near your o2 sensor you may get a check engine light for the same reason as mentioned before except now the o2 sensor will begin to read lean becasue of the air.... jsut replace it or weld it
96hatchBoy
Apr 14, 2013 11:27 AM
NinjaTech
Jun 19, 2005 08:56 PM
jweezy225
Nov 1, 2004 02:44 AM
d15maverick
16
May 8, 2004 10:28 AM
kay_animation
14
Feb 14, 2003 10:32 AM
