head rebuild now have a few simple problems
Old Mar 22, 2005 | 08:23 PM
sir2sol's Avatar
Default head rebuild now have a few simple problems
i recently just had the head rebuilt on my b16 and got it put together this last past weekend, now i have a few problems. the problem i'm worried most about is my vtec isn't working. it's almost like i'm running in safe mode. the engine has plenty of power, just no vtec. i was wondering if it might have something to do with the timing with my distributor. right now it's all the advanced towards the intake side. any suggestions would be great cause i'm kinda in the dark with this one.
Old Mar 22, 2005 | 08:56 PM
mike93eh
Guest
Posts: n/a
Default Re: head rebuild now have a few simple problems (sir2sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sir2sol &raquo;</TD></TR><TR><TD CLASS="quote">i recently just had the head rebuilt on my b16 and got it put together this last past weekend, now i have a few problems. the problem i'm worried most about is my vtec isn't working. it's almost like i'm running in safe mode. the engine has plenty of power, just no vtec. i was wondering if it might have something to do with the timing with my distributor. right now it's all the advanced towards the intake side. any suggestions would be great cause i'm kinda in the dark with this one.
that im sure isnt helping anything. get your timing set. throwing any CEL's? full on oil?
Old Mar 22, 2005 | 09:14 PM
sir2sol's Avatar
Default Re: head rebuild now have a few simple problems (mike93eh)
no check engine lights and i'm fairly sure that the oil is alright i'll have to check that. i'm doing some searching and i'm wondering if i might have a vacuum line messed up, but i can't find a diagram to help me out so i'm not sure about that.
Old Mar 22, 2005 | 09:37 PM
mike93eh
Guest
Posts: n/a
when you put the head back on, you put the oil jets in right position?
Old Mar 23, 2005 | 07:52 AM
sir2sol's Avatar
Default Re: (mike93eh)
yeah we got all of that stuff right, my buddy that helped me is real **** about stuff like that.
Old Mar 23, 2005 | 04:13 PM
jamey220's Avatar
Default Re: (sir2sol)
do u have the plugs all the way in ur ecu check them to make sure that they are in tight or u can take a 12v switch or push button hook it up to the selonoid and other to a constant hot when u go down the road turn it on about 5300rpms dont turn it on at low rpms do ur car will choke if that doesn't work then u have a bad selonoid.
TeranceFL
Jul 18, 2012 03:04 PM
robit50
Aug 1, 2010 09:06 PM
Blazen_angles
11
Dec 9, 2007 09:21 AM
Dav94Lx
Oct 12, 2007 08:28 PM
greddy13
Dec 17, 2006 09:53 AM
