Hardwiring question?
Old Dec 12, 2003 | 08:58 AM
mattssi's Avatar
Default Hardwiring question?
I am fed up with trial and error on the count that i am using a dx harness on a b16 in a car that was originally wired for the b16! So I am going to hard wire the sensors that are having trouble! My question is this!
When the ecu is showing only one output to the sensor, and the sensor has a 2 wire plug, does that mean that the sensor has a ground?
E.g.. engine coolant temp, Intake air temp, Idle control system?
Old Dec 12, 2003 | 09:55 AM
JimBlake's Avatar
Default Re: Hardwiring question? (mattssi)
Gotta look at the wiring diagram. Get a Helm book. Sometimes it's a ground, sometimes it's +12v power.
Old Jan 20, 2004 | 11:44 PM
sparxx's Avatar
temp sensors are called thermistors....power goes in through one wire, the sensor give resistances depending on temp and use...all temp sensors should have 2 wires.both going back to ecu...correct me if I'm wrong...Sup Matt
Old Jan 21, 2004 | 12:15 AM
Maintenance's Avatar
Default Re: Hardwiring question? (sparxx)
Which sensor are you trying to hard wire? Maybe I can look it up in the Helm's and help you out
KiwiRuss
Honda CR-V & Element
Apr 1, 2022 12:43 PM
ferio-ichi3
Jul 13, 2015 09:39 AM
mikegeezy
Oct 4, 2009 10:51 AM
byronl
Feb 17, 2007 03:26 PM
Twistedframe
Feb 5, 2004 07:53 AM
