Hardwiring question?
I am fed up with trial and error on the count that i am using a dx harness on a b16 in a car that was originally wired for the b16! So I am going to hard wire the sensors that are having trouble! My question is this!
When the ecu is showing only one output to the sensor, and the sensor has a 2 wire plug, does that mean that the sensor has a ground?
E.g.. engine coolant temp, Intake air temp, Idle control system?
temp sensors are called thermistors....power goes in through one wire, the sensor give resistances depending on temp and use...all temp sensors should have 2 wires.both going back to ecu...correct me if I'm wrong...Sup Matt
KiwiRuss
Honda CR-V & Element
Apr 1, 2022 12:43 PM
ferio-ichi3
Jul 13, 2015 09:39 AM
