hard to go in all gears. HELP!
Old Mar 13, 2007 | 12:32 AM
slayersluck's Avatar
Default hard to go in all gears. HELP!
Ok so it's been about almost 3 weeks now and i have been driving like this but I have to figure this out now. gsr tranny:
it all started with my shift linkage coming out.(the stabilizer one, not the one with the bitch pin). I think my bolt was loose or something. I had to call a tow truck to tow my car home and of course the shift linkage was hanging on the ground... the tow man brought the flat bed truck and when he was draging the car onto the flat bed, he bent my linkage so i had to buy a new one.
I bought a CTR linkage and I noticed that it didn't want to go in any gears. I have to play with it in order to get that sucker in. REVERSE is the hardest to go in and at first...i thought it might be a bent linkage. And so my friend let me try his integra linkage from his running car and for sure his linkage is fine. He let me try his and it's the exact same thing. any sugguestion?
And also something is making noises from the tranny area when the pedal is disengaged...but when engagged, the noise goes away. ANy SUGGESTION? I'm guessing it's the clutch. oh yeah...the car was driving FINE before the linkage incident...
Old Mar 13, 2007 | 12:34 AM
Default Re: hard to go in all gears. HELP! (slayersluck)
HELP A BROTHER OUTTTT!!!!
Old Mar 13, 2007 | 07:59 AM
Honda Bull's Avatar
He put the car up on the bed forwards? Not rear end first?
Old Mar 13, 2007 | 10:57 AM
Default Re: hard to go in all gears. HELP! (Honda Bull)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Bull &raquo;</TD></TR><TR><TD CLASS="quote">He put the car up on the bed forwards? Not rear end first?</TD></TR></TABLE>
yeah front first...so he bent the linkage. and that's when i bought a new one.
Old Mar 13, 2007 | 02:39 PM
gents97civ's Avatar
trans is damaged. your prob gonna need new shift forks.
Old Mar 13, 2007 | 04:27 PM
Default Re: (gents97civ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gents97civ &raquo;</TD></TR><TR><TD CLASS="quote">trans is damaged. your prob gonna need new shift forks.</TD></TR></TABLE>
can the clutch cause it to not go into gear?
Old Mar 13, 2007 | 04:29 PM
Default Re: (slayersluck)
any other input?
Old Mar 13, 2007 | 11:54 PM
Old Mar 14, 2007 | 07:00 AM
Honda Bull's Avatar
I'm going to say a possibility is that the rod inside the tranny (that the linkage (the end with the 'bitch pin') attaches to) has been damaged. I'd recommend pulling the tranny and inspecting it. If you're skeptical of doing it yourself, then try and find a friend or someone to help you out with it.
Old Mar 14, 2007 | 07:01 AM
Honda Bull's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slayersluck &raquo;</TD></TR><TR><TD CLASS="quote">
can the clutch cause it to not go into gear?</TD></TR></TABLE>
Bad pressure plate/broken springs can give you troubles.
Old Mar 14, 2007 | 10:53 AM
Default Re: (Honda Bull)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Bull &raquo;</TD></TR><TR><TD CLASS="quote">I'm going to say a possibility is that the rod inside the tranny (that the linkage (the end with the 'bitch pin') attaches to) has been damaged. I'd recommend pulling the tranny and inspecting it. If you're skeptical of doing it yourself, then try and find a friend or someone to help you out with it. </TD></TR></TABLE>
that's one of things i was thinking, i thought the rod might be bent since the incident. I'll pull out the tranny soon and find out. thanks.
Old Mar 15, 2007 | 11:41 AM
any other suggestion?
Alicali
Nov 30, 2016 09:23 AM
Thepowderblue
Jul 4, 2012 12:01 AM
JDMfan77
Jun 24, 2010 07:06 PM
vtechjunkie
41
Mar 7, 2010 07:47 PM
user7889
Sep 28, 2008 03:27 PM
