Halfshaft removal
Old Jul 27, 2004 | 08:30 PM
chevygonehonda's Avatar
Default Question on removing the halfshaft on the driver side of a 95 prelude
For short the only automobile i ever owned was a 81 Chevy pickup which is alot simplier than a 95 prelude. At least suspension wise. I am removing the halfshafts, I have the pass. side out, but not sure what to do on the driver side. It either has an extension shaft or the whole shaft comes out. If the whole shaft comes out then I figure the stabilizing bracket must come off too. What is the best way to remove this shaft? I have a manual tranny also, if that makes a difference.
Modified by chevygonehonda at 10:04 PM 7/27/2004
Old Jul 27, 2004 | 10:30 PM
spaceman's Avatar
Default Re: Question on removing the halfshaft on the driver side of a 95 prelude (chevygonehonda)
you should get a repair manual for your car..they help alot..also what your asking isnt too dificult if you get under it and take a good look at the situation..good luck
Old Jul 27, 2004 | 10:37 PM
IN VTEC's Avatar
I usually just remove the intermediate shaft and drive shaft in one piece. The drive shaft is too hard for me to pop out of the int. shaft if it's still bolted onto the engine.
Separate the axle from the hub, remove the three dowel bolts, and the whole thing will slide out easily from the tranny. Guide the support bracket so that it doesn't let it catch on the alternator or subframe (or whatever's in the way on a Prelude engine....not the alternator I know that).
Greatness
Jan 15, 2010 05:21 PM
Rhymenoceros
Nov 22, 2007 12:16 PM
zman
Jul 29, 2004 10:06 AM
