H23a vtech?
Old Apr 22, 2002 | 09:41 PM
4thgenturboSi's Avatar
New User
Default H23a vtech?
i saw a guy selling an H23a vtech, i was not aware a vtech h23 was made, or is this just a hybrid motor, (h23 block w/h22 head)?
Old Apr 22, 2002 | 09:53 PM
Accord94DX's Avatar
Default Re: H23a vtech? (4thgenturboSi)
VTEC. Not Vtech, veeteck, vetech, veeteckh, etc
there is a JDM H23 VTEC. It came in accord wagons.
[Modified by Accord94DX, 10:54 PM 4/22/2002]
Old Apr 22, 2002 | 10:01 PM
PrecisionH23a's Avatar
vtech is a phone! haha. anyways, if it is a h22/h23 hybrid be careful. I forgot the name of the team, but they went through 3 motors before they got this hybrid running correctly. It isnt that reliable, but yes it is powerful. just be careful someone isnt selling you the engine bc they couldnt get it running correctly. the h23a is a dohc non vtec engine, if it is vtec the vavle cover will say vtec and the block will read h23a.
Old Apr 22, 2002 | 10:29 PM
typeSwarrior's Avatar
Default Re: H23a vtech? (Accord94DX)
...there is a JDM H23 VTEC. It came in accord wagons.
I've just been enlightened...thanks. Where can I find specs on this particular motor?
Old Apr 22, 2002 | 10:33 PM
4bidden's Avatar
Default Re: H23a vtech? (typeSwarrior)
there were 2 versions...a dohc and a sohc model. the higher of the two, the dohc, makes the same hp as the jdm h22a, 200ps (197hp). it has about 13ft-lb more torque though.
Old Apr 23, 2002 | 04:58 AM
Nick H's Avatar
New User
Default Re: H23a vtech? (4bidden)
actually 220 ps which is close to 215 hp
Old Apr 23, 2002 | 05:33 AM
aklucsarits's Avatar
New User
Default Re: H23a vtech? (nickh2k1)
4bidden was correct. The DOHC VTEC H23a is rated at 200ps@6800rpm. It is tuned for a little more torque - 221Nm@5300rpm - What's that in lb.ft?
DOHC VTEC H23A Accord SiR Wagon Specs on <A HREF="http://www.honda.co.jp" TARGET="_blank">http://www.honda.co.jp</A>
Andrew
Old Apr 23, 2002 | 05:36 AM
New User
Default Re: H23a vtech? (aklucsarits)
Grrr.... That link through bablefish does not work right... Here's a direct link: http://www.honda.co.jp/auto-lineup/a..._data/sir.html
You can go to altavistsa.com and put that URL in the bablefish translator for Engrish.
Andrew
Old Apr 23, 2002 | 07:12 AM
4bidden's Avatar
a lot of people thought that it had as much hp as the type-s, 220ps, but it doesnt. it has 200ps as stated on the honda of japan website.
Old Apr 23, 2002 | 04:24 PM
JinMTVT's Avatar
New User
i'ts 220ps but only using an H22a ecu you can get near 215hp on that engine..
best option is to get the H23 vtec..swap cams for aftermarkets like crower or juns or maybe euro R intake cam + type S exhaust cam
then run it on a h22a spoon ecu
or even better..get a euro R int. manifold and use a mugen 1.8 ITR ecu
ahha
kaboum at 8500rpm
Old Apr 23, 2002 | 11:05 PM
4bidden's Avatar
Default Re: H23a vtech? (JinMTVT)
where do you see some proof of 220ps on the h23 vtec?
Old Apr 24, 2002 | 06:29 PM
renahec's Avatar
so what is an H23A1?
Old Apr 24, 2002 | 08:28 PM
JinMTVT's Avatar
New User
sorry...i meant 200ps
eheh
my bad
titan2nv
Oct 19, 2006 10:22 AM
foshizllmynizl
Aug 21, 2004 03:41 AM
BlueFang08
Apr 30, 2003 11:39 AM
sayjdm
Feb 10, 2002 03:29 PM
