H22A vs. F20B
Old 07-31-2006, 09:14 PM
99h22ek's Avatar
Default H22A vs. F20B
HP, TQ, RELIABILITY, PROBLEMS, etc.
I know the H22a inside out. I was told that the F20b fits into the H tranny so Im contemplating a quick longblock swap. Contribute as you please.
H22A
HP: 200 TQ: 156ft/lbs
RELIABILITY/PROBLEMS: made from an atypical metal that tends to warp over time under high pressure and temps. Causes piston rings to oval and cylinder walls begin to score causing noticeable oil consumption.
Any information on how this compares to the F20b, please provide...Or if you want to provide more info on the 2-2, all is welcome for the sake of education. Just dont bs.
Old 08-02-2006, 01:08 PM
99h22ek's Avatar
Default Re: H22A vs. F20B (99h22ek)
so im hearing...
F20b has cast iron sleeves as oppose to the H22a aluminum sleeves.
+1 for the F
anybody konw anything? i understand its a rare motor...not too much konwledge out there.
Old 09-15-2006, 01:07 PM
99h22ek's Avatar
in short
H22a vs F20B
2.2L displacement 2.0L
200 hp 200 manual, 180 auto
156ft/lbs torque 148ft/lbs
Fibre-reinforced mesh sleeves thicker cast iron sleeves
11.5mm throttle body smaller
87mm stroke 85mm
solid cams auto:shitty, manual:solid
...anyhow, I swapped out my boxed 2.2 and opted for the F20B out of a 2001 automatic euro accord SIR. figured this way id get a motor in great shape, not to mention id be swapping out the cams regardless next summer. overall, the motor's a beaut.
xxx99ludexxx
01-30-2016 04:27 AM
otacon122
10-28-2008 05:13 PM
Neondog82
06-18-2004 01:15 AM
275Performance
11-18-2002 05:49 AM
Quick Reply: H22A vs. F20B
