h22a turbo teg, radiator?
Old 02-07-2004, 03:38 PM
b16hybridsol's Avatar
Default h22a turbo teg, radiator?
ok i started putting my turbo kit on today and the stock radiator won't fit, my set up is f-max manifold with a t3/60-1, now i have a del sol vtec, and i measured its radiator and its still to big, the max width the radiator can be is like 12 inches wide. Height and thickness isn't and issue, its just that the turbo sticks out way to far, i though about putting in a del sol vtec radiator at a little bit of an angle but then i dunno if i'll have room for the intercooler piping. Has any one else had this problem, i don't really have much to spend on another radiator so i was wondering if theres any radiator out of some other car or if there some radiator that i could mount like under the hood release lever, kinda like <U>in</U> the radiator support. any help would be greatly appriciated thanks
Old 05-05-2004, 10:26 PM
Siriuswerks's Avatar
Default Re: h22a turbo teg, radiator? (b16hybridsol)
im having the same problem as we speak. My set up is different, I have a h22a EG (92-95) Civic. THe radiator is to fat. I have a Dual COre radiator. Im THinking of going back to the single core radiator. Im also running a fal Fan and Air-water Intercooler.
Old 05-06-2004, 03:53 AM
1700anddroping's Avatar
Default Re: h22a turbo teg, radiator? (SiRiUsWeRkS)
i had the same problem ,this what i done.i took the rubber mounts off the bottom of the rad. so it would sit lower,i then mounted the fan in the fron of rad. i also had to make a little indention under my hood for the rad. to clear and shut.i also made a custom bracket to pull the rad. back and my **** was touching,now its not .i am running the turbonetics pro race gate and this thing is huge.i hope this helps and good luck with your project.
Old 05-06-2004, 07:02 PM
Default Re: h22a turbo teg, radiator? (1700anddroping)
do you have any pics? im gonna try a single core radiator.
Old 05-06-2004, 09:07 PM
no but i can take some and send them to you,just need your email addy.
Old 05-06-2004, 09:39 PM
boostn420's Avatar
you guys need a different manifold and use the normal parts.
Old 05-06-2004, 09:49 PM
Default Re: h22a turbo teg, radiator? (boostn420)
turbocharging a non turbo car crosses the normal line
Old 05-07-2004, 05:20 AM
and what is exactly? normal parts.
Old 05-20-2004, 12:02 PM
I did it with the single core fan and a log manifold from rev hard using a pwr air to water intercooler i will have pics later on next week when i get my fuel cell in
97dc2
01-01-2006 10:03 PM
redzcstandardhatch
02-01-2005 04:19 PM
Vinhtran17
08-30-2004 07:56 PM
BoOsTiN Dc2
05-23-2004 04:43 PM
Quick Reply: h22a turbo teg, radiator?
