h22 injectors wont spray
Old Mar 23, 2005 | 03:59 PM
jamey220's Avatar
Default h22 injectors wont spray
i have an h22 in my 90 accord but my injectors will not spray any gas, i sprayed nitrous to the engine only one time it was a 30 shot after that i heard the engine sounding like the plugs were dead, the next day i changed them but still did not fix the problem, then i took my injectors out set them on a rag turned my ignition no gas came out, i changed the fuel pump, filter, resistor box and main realy and wiring harness dont know what else it could be any help would be great.
Old Mar 23, 2005 | 04:25 PM
PrettyLude's Avatar
any cels?
Old Mar 23, 2005 | 04:47 PM
jamey220's Avatar
Default Re: (PrettyLude)
no cels i have a customized dash with gauges in it so i wouldnt know.
Old Mar 23, 2005 | 05:33 PM
Dragline's Avatar
Default Re: (jamey220)
Does your fuel pump run when you turn the key on?
Old Mar 23, 2005 | 06:16 PM
jamey220's Avatar
Default Re: (dragline)
yes everything works i can hear the fuel pump come on when i turn the switch and gas is also going through the fuel rail, injectors are not opening up, if i take a ground wire and touch the injector it will open up.
Old Mar 24, 2005 | 04:26 PM
PrettyLude's Avatar
check all your grounds, especially the one at the Tstat housing
Old Mar 24, 2005 | 04:45 PM
Dragline's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">check all your grounds, especially the one at the Tstat housing</TD></TR></TABLE>
Also check for 12v at your injectors.
Old Mar 24, 2005 | 05:16 PM
jamey220's Avatar
my ground is good and there is 12volts present at each injector.
Old Mar 29, 2005 | 03:42 PM
jamey220's Avatar
does anybody else have any idea what it could be?
crx2hatch
14
Jan 4, 2014 12:34 PM
dadrought6
Jun 29, 2009 12:46 PM
CLE
Jul 13, 2006 02:25 PM
alleyezonme
Feb 3, 2006 08:04 PM
