H22 blowing flames
Old Dec 10, 2006 | 02:52 PM
ONELIFEMOTORSPORTS's Avatar
Default H22 blowing flames
Got a 94 prelude with a H22, just put a Skunk 2 intake manifold, throttle body and a fuel rail on it. Idles choppy and has no throttle response sounds like it misses till about 3000 rpm and then all is well. But it blows flames out the exhaust and whem i shut it off i look in the muffler and its glowin red!!! Why would a new intake and throttle body cause it to run RICH like this... ive put 3 sets of plugs in it and when i look at them they are soaked in gas!!! please help
Old Dec 10, 2006 | 04:04 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: H22 blowing flames (ONELIFEMOTORSPORTS)
bump for the answer for this guy before his **** melts
Old Dec 10, 2006 | 05:56 PM
high_revs's Avatar
too much fuel
Old Dec 10, 2006 | 05:57 PM
high_revs's Avatar
your regulator might be bad and causing excess pressure...
Old Dec 10, 2006 | 05:58 PM
Qfactor's Avatar
check tps voltage, new TB do not come with tps you most likely did not set it right to specs, or maybe you crossed the TPS and Map sensor plugs, or check map sensor vacuum port to make sure is cleared of any shavings.
Old Dec 10, 2006 | 06:07 PM
high_revs's Avatar
tps plug and map sensor switched it prob wouldnt start but it happens often...and was the tps on the new tb removed??? it should have the stock bolts that "cant be removed" nothing a saw and flat head cant handle lol
Old Dec 10, 2006 | 08:08 PM
EJgsr's Avatar
Default Re: (SB tuning)
its the TPS. thats the only logical thing that it would be...
Old Dec 10, 2006 | 08:36 PM
Garage 808 Hatch's Avatar
a bad fpr would cause this also. i had an aem and the diapram went bad, pour gas into the mani through the vacuum line. causing it to load up and shoot flames
Old Dec 11, 2006 | 03:07 AM
Default Re: (Garage 808 Hatch)
ill check the tps, I just cut grooves in the old and flatheaded them out. What should the voltage be on the tps??? Thanx techies
Old Dec 11, 2006 | 11:14 AM
jays93eg6's Avatar
Default Re: (ONELIFEMOTORSPORTS)
Im down with the TPS as well. I thought that was the problem I was having with my swap, but turned out to be a really shi@y Ebay chip and no cat. Damn car threw flames everytime I shifted over 7K. It was cool to see at night, to bad the cops didn't see it that way.
Old Dec 11, 2006 | 06:56 PM
high_revs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ONELIFEMOTORSPORTS &raquo;</TD></TR><TR><TD CLASS="quote">ill check the tps, I just cut grooves in the old and flatheaded them out. What should the voltage be on the tps??? Thanx techies</TD></TR></TABLE>
.5 closed 4.5 WOT
Old Dec 12, 2006 | 02:36 AM
IN VTEC's Avatar
I vote for ignition misfire or the MAP sensor isn't seeing proper manifold pressure.
Check the orientation of the plug wires and that the MAP sensor has a manifold vacuum source.
Old Dec 12, 2006 | 05:35 AM
Default Re: H22 blowing flames (IN VTEC)
well its a rainy day im going to try all that is suggested!! Thanx again
Old Dec 12, 2006 | 06:39 PM
well i have a EGR code and a O2 sensor code. It has a hole in the exhaust more towards the rear section of the car so its really loud. But i was checking over things today and It has a leak where the 4 to 2 come together could that cause the O2 sensor the think there is fresh air in there and giving it lots of fuel to compensate????
Old Dec 13, 2006 | 05:22 AM
IN VTEC's Avatar
Yes. Any upstream leaks can affect o2 sensor readings.
A stuck or partially open EGR can also cause a rough idle. Check to see which EGR code its throwing and address the problem.
Old Dec 17, 2006 | 06:15 AM
Solved thanx everybody!!!!
Old Dec 17, 2006 | 06:40 AM
high_revs's Avatar
what was the problem
Old Dec 17, 2006 | 03:38 PM
well the tps was not clocked correct and i had a exhaust leak before the o2 sensor fixed them both drove great!!! then i let it idle for like and hour it ran out of gas and now fried the fuel pump!!
Old Dec 17, 2006 | 03:44 PM
Brick Top's Avatar
my friends h22 inside muffler was glowing and blowing out sparks a few times.
i think ever since he installed his skunk2 mani and removed his egr its been happening.
Old Dec 17, 2006 | 08:39 PM
high_revs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ONELIFEMOTORSPORTS &raquo;</TD></TR><TR><TD CLASS="quote">well the tps was not clocked correct and i had a exhaust leak before the o2 sensor fixed them both drove great!!! then i let it idle for like and hour it ran out of gas and now fried the fuel pump!!</TD></TR></TABLE>
guess your just having bad luck lol
jake1191
Engine Management and Tuning
Jul 18, 2011 06:42 AM
Hardedge
Dec 5, 2007 05:40 PM
crfr230
Apr 20, 2007 05:12 PM
PearlBlueType-S
Jan 7, 2006 09:27 AM
AmonDin
Jun 22, 2005 02:49 PM
