H block hone statement
h22a motors have f.r.m sleeves the sleeves are aluminium and have a special silicon finish on them and to the response of .020 not being alot to the eye its not alot but when it comes to machining it is .001 is normal when you have .004 you exceed some service limits why i tell people to sleeve h22a motors is so they can use which ever piston they want when you bore a h22a you must resilicon the sleeve you cant even hone it
I typically don't put much faith in the words of someone who writes that poorly. I mean seriously, that's pretty bad!
So apparently you can hone the FRM sleeves, just not like you can other engines with trypical ductile iron liners.
DragSource
Mar 31, 2005 11:26 AM
