GSR Vtec wiring problem in EG
Old May 9, 2003 | 05:51 PM
  #26
made in JAPAN's Avatar
Default Re: GSR Vtec wiring problem in EG (shorty)
sorry to bring back an old post, but did you fix this yet?? im having the same problem, but with an ls/vtec in a 92 integra. was running a fields controller on stock ecu, now im using a p28 chipped.
Old May 10, 2003 | 09:55 AM
  #27
xpurespeedx's Avatar
Default Re: GSR Vtec wiring problem in EG (made in JAPAN)
I used my old DX harness for my 96 gsr swap in my 94 civic and I had to hook up a vtec solenoid wire, vtec oil pressure wire, and a ground. This is with a obd1 gsr usdm computer. My vtec works fine, so make sure you have all the wires hooked up.Good Luck if you havent already fixed it.
Old May 10, 2003 | 12:41 PM
  #28
TuRbEeZy's Avatar
Did you use a ground? Cuz if not then vtec wont work, this is what happened to my friends car after the swap and no ground the vtec didnt work.
Old May 10, 2003 | 01:44 PM
  #29
95civichybrid's Avatar
why don't you just order a new harness from hasport. $75 and free shipping.
Old May 12, 2003 | 07:06 PM
  #30
92HB_HB's Avatar
Default Re: GSR Vtec wiring problem in EG (TuRbEeZy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TuRbEeZy &raquo;</TD></TR><TR><TD CLASS="quote">Did you use a ground? Cuz if not then vtec wont work, this is what happened to my friends car after the swap and no ground the vtec didnt work.</TD></TR></TABLE>
how do you ground the vtec?? where's the wire on the harness?? thanks.. myabe thats my problem also
EGThang
18
Jun 6, 2008 03:26 PM
crx18c1
18
Apr 12, 2007 12:25 PM
JDMBoi
Apr 26, 2005 02:16 PM
The Mista Mike
Mar 12, 2005 12:26 PM
shorty
18
Mar 31, 2003 04:24 PM
