GSR into a Civic ex, help!!!! asap please
quick tech issue,
first time swap just got a 98 usdm b18c1 w/ all swap parts, however, I didn't get the wiring harness that goes to the ecu, I'm putting the motor into a 98 civic ex(5-speed). could i use the one I have in the civic? will this need serious know-how? I really could use help
any other info about this swap will be useful
thanks,
Jeph
thanks,
Jeph
Wrong forum you noob but its ok welcome to HT.Anyways to answer you question you can use your ex harness but you will have to wire up your IAB sensor and i believe your knock sensor.Go to the hybrid forum and also do a search.Hope that helps.
98civicGSR
Mar 26, 2003 04:24 PM
