GSR head on LS bottom HELP???
Old Sep 20, 2004 | 06:12 PM
93gsrcoupe's Avatar
Default GSR head on LS bottom HELP???
Now before I start, I just want to say that I've searched and I can't find anything addressing this exact problem. I have a friend putting a GSR head on his LS bottom and he's having some trouble. One thing is that he's using the stock GSR intake manifold on and he says there are plugs that have no place. Now keep in mind that he still has the LS harness. Will there be any problems using the LS plugs(besides the butterflies not working)? The other question is will the vtec work with just a vtec controller and no vtec ecu? He says it can, and I disagree, so who's right?
Old Sep 20, 2004 | 07:31 PM
sledgehammer's Avatar
Default Re: GSR head on LS bottom HELP??? (93gsrcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93gsrcoupe &raquo;</TD></TR><TR><TD CLASS="quote">Now before I start, I just want to say that I've searched and I can't find anything addressing this exact problem. I have a friend putting a GSR head on his LS bottom and he's having some trouble. One thing is that he's using the stock GSR intake manifold on and he says there are plugs that have no place. Now keep in mind that he still has the LS harness. Will there be any problems using the LS plugs(besides the butterflies not working)? The other question is will the vtec work with just a vtec controller and no vtec ecu? He says it can, and I disagree, so who's right?</TD></TR></TABLE>
Well hes going to definitely need a vtec ecu. Otherwise theres no signal to the motor to activate it. The VAFC controller is a piggyback, meaning it has the abilty to modify whats already there.
Mike
Old Sep 20, 2004 | 07:49 PM
NeKe1point0's Avatar
Default Re: GSR head on LS bottom HELP??? (sledgehammer)
my friend built his Ls/Vtec in a 94 teg.. What he said the ecu is the only way vtec knows when to crack
Old Sep 21, 2004 | 03:26 PM
93gsrcoupe's Avatar
What about the intake manifold? Does he need the GSR harness as well to hook it up?
Old Sep 21, 2004 | 07:19 PM
93gsrcoupe's Avatar
Bump.....come on people, somebody has got to know the answers.
Old Sep 21, 2004 | 07:23 PM
opkjoblacsh's Avatar
that would make sense to have a gsr harness since you are making the motor pretty much are b18c the vtec is going to have to plug in somewhere but thats just my 2cents
Old Sep 21, 2004 | 07:46 PM
93lsd's Avatar
you can use a non vtec ecu with a vtec cont, the only bad thing is that you cannot get full power having too shift a 7,000 and needing to add more fuel when vtec kicks, because you will run lean in vtec or you will not have full power. just spend the money and get the right ecu..
Old Sep 21, 2004 | 07:57 PM
93gsrcoupe's Avatar
So basically what you all are saying is that he NEEDS the GSR HARNESS and a VTEC ECU in order for this motor to work, cuz nothing is plugging into that intake manifold. What about the fuel rail? He has the GSR rail and injectors, but they won't plug in either. Can he use the LS injectors on the GSR rail, or what?
Old Sep 22, 2004 | 07:33 AM
93gsrcoupe's Avatar
Bump for Lunch
Old Sep 22, 2004 | 07:54 AM
mmuller's Avatar
Mad Scientist
you can activate vtec through a vafc, but it's not the same as using a vetc ecu since timing will still be off. the mid lobe has different timing maps than the pri/sec lobes.
as far as the harness you can use your ls one, just wire for iab's, and vtec
JWHATCH23
Oct 11, 2006 11:20 PM
mxler8
Jul 27, 2004 07:57 PM
DrewQ1
Jul 17, 2004 12:10 PM
jdmjeff
Apr 16, 2004 09:48 PM
tegasaurus
Dec 10, 2002 07:46 AM
