GSR B18C1 Head Question
Old Apr 24, 2005 | 09:15 AM
pcguy760's Avatar
Default GSR B18C1 Head Question
Hi, I am currently putting together a B18C1 that is going to be OBD1 since my car already is OBD1.
I would like to know what difference is there between the OBD1 and OBD2 GSR Head?
If I get a OBD2 head what do I need to do to make it work or am I better off with a OBD1 head?
BTW I am still looking for a complete head...
Thanks.
Old Apr 24, 2005 | 03:03 PM
zman's Avatar
Default Re: GSR B18C1 Head Question (pcguy760)
all you would need to make it work is an obd1 distributor and obd1 injectors. Other than that i don't know what the difference would be, prolly not any gain in performance with 1 over the other.
Old Apr 24, 2005 | 03:35 PM
mmuller's Avatar
Mad Scientist
its plug and play; if using a obd2 dizzy all you need to do is re-pin the plug
Old Apr 24, 2005 | 03:59 PM
zman's Avatar
Default Re: GSR B18C1 Head Question (mmuller)
^^^^^thats not true. My my dizzy bearing took a crap on me on my obd1 b16 so i got an obd2 gsr dizzy. I tried to repin the plug, and even did it sucessfully, so i thought, but the plug on the dizzy wouldn't plug into the plug on the harness. The pins on the obd2 dizzy are longer and don't fit into the plug on the harness side properly. I used the plugs from the b16's dizzy (b/c obd1 dizzy's use 2 plugs and obd2 use 1 big plug) so they would plug into the harness but it wouldn't fit right
So, just cut the plugs off, soldered and shrink wrapped the wires....haven't had a problem since.
Old Apr 24, 2005 | 04:25 PM
mmuller's Avatar
Mad Scientist
Default Re: GSR B18C1 Head Question (zman)
thats what i ment, change plugs to match wichever side you would like.
better?
Old Apr 24, 2005 | 08:36 PM
zman's Avatar
but the pins on the obd1 plugs and the pins on the obd2 plug are different. I don't see how changing the plug will allow them to plug in properly. Unless using the obd2 harness plug allows this, but i didn't try that.
Another way is cutting the distributor plug off the harness from an obd2 integra and soldering it onto the harness from your car....if you really wanted to keep the plug on there.
Old Apr 25, 2005 | 06:49 AM
mmuller's Avatar
Mad Scientist
only the 2 ign wires have different pin sizes.
Old Apr 25, 2005 | 06:54 AM
zman's Avatar
well than i must have been doing something wrong because after i put the obd1 plugs onto the obd2 gsr dizzy they wouldnt plug in all of the way....i noticed that the pins on the obd2 dizzy were longer than the pins on the obd1 dizzy.
what is that a pic of? .....and don't say the dizzy plug....i know that much....but which one?
DA3DC2
Jan 9, 2010 06:41 PM
ALLMOT0REJ1
Jan 2, 2010 05:51 AM
gnccracer20
Mar 22, 2009 08:05 PM
gezer
Aug 26, 2004 10:42 PM
ljoe
Oct 10, 2003 03:55 PM
