got the mpfi done!! now i need help
Old Aug 19, 2004 | 10:30 AM
noob2k's Avatar
Default got the mpfi done!! now i need help
i did the mpfi swap used fourthgenhatch's direction's so now whats the next step i have everything done up to the the point of wires goign to the resistor box but i wanna skip that process and run with out the resistor box and just go with the d1 injectors
thanks kevin
Old Aug 19, 2004 | 11:48 AM
tgreaves's Avatar
Default Re: got the mpfi done!! now i need help (noob2k)
Did you do everything on the mpfi conversion list.. I guess the next step would be to start the car and make sure everything works good..
Old Aug 19, 2004 | 03:22 PM
noob2k's Avatar
Default Re: got the mpfi done!! now i need help (tgreaves)
i did do everything on the mpfi list except wire up to the resistor box i wanna know how to run obd1 injectors and not use the resistor box i have a p28 ecu
92 teggy
13
Feb 22, 2010 08:22 PM
SupraRXZ
Jan 31, 2006 09:07 PM
7rrivera7
Jan 17, 2005 02:07 PM
SteveeeO
Mar 3, 2003 07:38 PM
