Golden Eagle Deck Plates.....
Old Sep 9, 2002 | 11:01 AM
  #26
canuck-mx6's Avatar
Default Re: Golden Eagle Deck Plates..... (Spade)
http://www.goldeneaglemfg.com
There are many many many combinations to bore and stroke an engine. Especially one with a modified block.
Not for golden eagle, for Eagle that makes rods, stroker cranks etc
Old Sep 9, 2002 | 12:12 PM
  #27
Spade's Avatar
Default Re: Golden Eagle Deck Plates..... (canuck-mx6)
Oh, I see. No, eagle doesn't have a web site as far as a week ago.
You have to get the catalog. Or find someone who has it.
Old Sep 9, 2002 | 12:45 PM
  #28
Civicdrgrcr's Avatar
From: WTF DC Racer No Way Turbo Washington., DC, USA
Default Re: Golden Eagle Deck Plates..... (badCRX)
Here is an email I received from him a few months ago when I inquired to the deck plate:
O.K., here are the procedures below and the total cost for everything.
Sleeved
Deck Plate Installed
Decked ( O-ring optional depending on piston size, but included in total price! )
Line bored ( recommended on any block!!! )
Bored & Honed
Arias Pistons w/ Ring and Wrist Pins
Eagle Long Rods
95 mm Eagle Crank
Water Pump Idler Plate that allows the use of a stock timing belt (requires an electric water pump)
Long ARP head studs to accommodate the deck height increase
Balanced Rotating Assembly
Polished and Oil Hole Chamfered Crank
New Rod Bearings
New Main Bearings
New Thrust Bearings
Full Cleaning
New Factory Oil Pump
Blueprint and Assembly
Total is $4237.00
Price reflects shelf stock pistons. Custom pistons add $70. Some items, not mentioned above, may need to be added to the total depending on the shape of the block, crank and other items received by Golden Eagle Mfg. , sent by the customer. This is only a quote and is not a guarantee that the price quoted will be the price for completion. Golden Eagle Mfg. REQUIRES at least a 50% deposit before any work is to be started. The remaining 50% must be received before release of the product to the customer. For questions or comments, please call us at (909) 592 - 4311.
I am sorry to say that we do not sell deck plate blocks by themselves. We require the motor to be built here for reliability and performance purposes. If you have any other questions about the procedures of our builds, please let me know anytime.
Thanks for your interest and hope to hear from you soon.
Regards,
Vince Tiaga
Golden Eagle Mfg.
vince@goldeneaglemfg.com
(909) 592 - 4311
I payed $1115 for my blocked to be sleeved and decked out. I was then told its about $800 for the crank. Then pistons, rods, bearings, thrust washers. $4000+ **** thats way over my head. I know it's not going to be that expensive.
Old Sep 9, 2002 | 02:17 PM
  #29
earl's Avatar
Default Re: Golden Eagle Deck Plates..... (Civicdrgrcr)
Speed costs $$. How fast do you want to go?
You can buy the exact same block in my 9.40 race car for $3000 complete. Much less than that if you already have a sleeved block ready to go.
Old Sep 9, 2002 | 08:17 PM
  #30
Default Re: Golden Eagle Deck Plates..... (earl)
I know speed cost money. I can keep on going on stuff I have spent on my just building the engine.
GSR Bare race head $1000
Ferrea valve terrain $600
T63 Turbo $950 with flange
GE Sleeves and deck plate $1115
Custom T4 turbo manifold $650
JG Intake manifold $330
72lb injectors $350
etc....
I had to change my setup like 2-3 times already before I finally made up my mind. I first was going to go 1.8 sleeved ge ls/vtec i already bought the eagle rods, and arias pistons for that setup. But then decided to go with the deck plate, so everything changed. I know speed cost money.
jdmeg6fan
Engine Machining & Assembly
Dec 29, 2016 09:51 PM
DC2_117
Mid-Atlantic (Sales)
Nov 18, 2011 11:02 AM
weiRtech
Aug 24, 2006 11:00 AM
done
Sep 30, 2004 04:53 PM
integra6650
Oct 9, 2003 07:18 AM
