Girdles? - for LS/Vtec
Old May 8, 2004 | 12:29 PM
N20civicB18's Avatar
Default Girdles? - for LS/Vtec
Should I buy a new OEM type-r girdle or I seen aftermarket ones forsale for about $200 makde out of 6061 i belive. What one is better? would I even need the aftermarket one or will the type-r one be just fine?
this will be for a turbocharged LS/vtec
Thanks guys
Kyle
Old May 9, 2004 | 06:54 AM
Rod.'s Avatar
Default Re: Girdles? - for LS/Vtec (N20civicB18)
you do not need a girdle. I am not going to use one on my lsvtec turbo.
Old May 9, 2004 | 07:53 AM
Race Egr's Avatar
Default Re: Girdles? - for LS/Vtec (redturbocivic)
yeah i wouldnt use a girdle either.
To do it right you have to get it dowled then get ur mains line honed.
Old May 9, 2004 | 08:13 AM
mmuller's Avatar
Mad Scientist
Default Re: Girdles? - for LS/Vtec (ek-guru)
yeah, instead of getting a griddle, you better off getting the whole rotating assembly balanced
Old May 9, 2004 | 09:12 AM
boostn420's Avatar
Buy the aftermatket one, it will need less machining. I believe you still have to have the OG bearing cap holes enlargened to put some shuffle pins for alignment (like the head). If you use a factory girdle then you have to do that plus shve down material in certain areas where it touches.
Balancing is a must for Ls/Vtec.
Old May 9, 2004 | 04:09 PM
Default Re: Girdles? - for LS/Vtec (boostn420)
well this is my plans for the motor, JE pistons 9.0:1, eagle rods, stock crank - yes i will be having it all balanced since it is only like 200$ I think I want to get a girdle and oil squirters. aftermarket girdles are suppost to be bolt on with no mods and they are only $200. I am unsure about the oil squirter setup as well - i know it cost about 150$ for the parts, but does it bolt on or where do I drill the holes? I will be useing a GSR oil,water pumps, timming bent and tensioner with a late 80's early 90's stock B16 head. I will be using a block guard - got one from KMS (off of ebay) and Im thinking about putting those Block posts in it to (drill in the middle of the block and insert threaded rod. to support the cylinders aswell. I plan to keep the stock bore but just hone it. I am unsure of what bearing to use and what headgasket. I plan to run around 15lbs safely (as long as I can get the proper fuel managment)
Any sugestions?
Oh yeah I currently have a B18B1 turbo in my 95 civic (but I have a spare B18B1 block i will be doing this to) I already have the head, oiling kit, dowel pins, block guard and some other little things...
Kyle
Old Jan 31, 2007 | 06:58 PM
Daniel-sanB1's Avatar
I'm in pretty much the same situation.
Adding a B16 Head to my turbo B18
do I need the girdles ?
Old Jan 31, 2007 | 09:03 PM
boosted96teg's Avatar
Default Re: Girdles? - for LS/Vtec (Daniel-sanB1)
I have a built LS/vtec with 600+ hp I got the Golden eagle girdle kit. It came with the girdle, GSR windage tray, GSR oil pick up, ARP main studs and dowel pins for the alinement. It cost 495. On my old set-up with 320hp I didn't have a girdle and my car was as reliable as stock, never gave me one problem. It really depends on ur set-up. If its just a mild setup dont worry about it. If ur going all out I would get one.
Old Feb 1, 2007 | 07:26 AM
Honda Bull's Avatar
Default Re: Girdles? - for LS/Vtec (boosted96teg)
A friend used GSR girdle and mains on his LS-VTEC. They didn't need align honed at all. He just had them checked and it all lined up fine. But for some I'm sure that you will. Nothing wrong with running one... but nothing really wrong without running one either.
Your choice.
Old Feb 3, 2007 | 07:18 AM
Default Re: Girdles? - for LS/Vtec (Honda Bull)
You must line hone it. I ended up just picking up a GSR bottom end for 150$ and using that with everything I needed and not needing to line hone it.
Old Feb 3, 2007 | 08:43 AM
Stock B18B
with a stock B16 head with stock GSR cams.
only thing after market is a Skunk2 cams seals and ARP head studs.
not planning on revving it pass 8k.
and she's boosted on 10psi
tuned
DADADAAAMN
Mar 5, 2006 09:42 PM
KornyCivic
Nov 15, 2005 12:41 PM
projectTeG
Nov 9, 2003 11:32 AM
Thrashin
Apr 1, 2003 04:39 PM
