General bottom end building???
Old Jan 9, 2003 | 11:48 AM
advanracing62's Avatar
Default General bottom end building???
Here's what I plan on doing, if you have any suggestions let me know... I really just want to do this once.
Balance rotating assembley
Micropolish crank
Slightly knife edge crank
Ceramic coat piston tops
Hone and over bore .25
ARP bolts
Align hone mains
Shot peen rods (ITR)
This will be used for a NA application, I'm not sure if the coating of the pistons is necessary?
Old Jan 9, 2003 | 11:53 AM
Spade's Avatar
Default Re: General bottom end building??? (advanracing62)
Do not knife edge the crank.....the TOP pro racers don't for a reason.
Old Jan 9, 2003 | 07:50 PM
1SlowB16EF's Avatar
knife edging is BAD.... i would only recommend ceramic coating the piston tops if you are planning ALOT!!! of boost or N2o
[Modified by 1SlowB16EF, 11:50 PM 1/9/2003]
Old Jan 9, 2003 | 08:24 PM
Default Re: General bottom end building??? (1SlowB16EF)
Ok so no knife edge, and no coating... looks like I'll be saving a bit of $$ here!
Old Jan 9, 2003 | 08:29 PM
GZERO's Avatar
Default Re: General bottom end building??? (Spade)
SPade, first time i heard that is not good to do, please tell me why? i just want to learn about it.
Old Jan 9, 2003 | 08:44 PM
earl's Avatar
I would not do the align hone unless the block was out of align. That can do more harm than good if the block is already correct.
yungkhmer
Apr 12, 2015 01:37 AM
Justacleansi
Jan 24, 2006 12:23 PM
caspers_hatch
Mar 20, 2005 07:52 PM
