87 Civic Si Help..
87 Civic Si Help..
I was trying down the road today and stopped to get gas.. I pulled out and the shifter was working fine... When I got to the exit I needed, it suddenly wouldn't let me gear down.. Now it is hard to get into gear.. Once you're going it's fine but still doesn't want to gear down.. Thinking it's a loose clutch.. Anyone have any ideas?
Re: 87 Civic Si Help..
I played with the adjustments today... I started and drove it a bit then it worked fine... After a little while it started not wanting to go into gear again..
i had the same problem with my 90 hatch. it turned out that the fluid level in the trans was very low. i had to double clutch for every gear. check the fluid level. if the gears aint properly lubricated, the gears wont mesh nicely
hurleyint1386
14
01-19-2006 03:09 PM
