GD MF POS AXLE NUT!!!!
Old Oct 15, 2001 | 06:30 PM
  #26
DragII's Avatar
25 Year Member
Default Re: GD MF POS AXLE NUT!!!! (turboEF ZC)
Turbo EF....tried that
lowsol: your Idea is up next
Old Oct 15, 2001 | 08:08 PM
  #27
SCsol's Avatar
Default Re: GD MF POS AXLE NUT!!!! (DragIIcivic)
trust me mine wont let you down you may need some one to hit the breaks your going to need the nut scocket to be about 3" long for best results also make sure the pipe wrench is about 24" so it has good grip tell me how it works out
Old Oct 16, 2001 | 07:09 AM
  #28
bigTom's Avatar
Default Re: GD MF POS AXLE NUT!!!! (lowsol)
took off my friends axles the other day on his 91 gsx... they have never been taken off... those things wouldnt budge for anything... breaker bar on it... jumping on the damn breaker bar and nothing! (i weigh about 170) then what i did... i put the 32mm socket on the nut... banged it hard with a hammer about 10-15 times... and the nut came right off
Old Oct 16, 2001 | 10:27 AM
  #29
AshlandSi's Avatar
2 and counting
Jesus man, you either must be Superman or you're using some bitch-*** breaker bars. My neighbor has a bar we call the enforcer. It's about 3 feet long, 1" thick (solid steel), has a non-ratcheting head, and 3/4" drive. There's no way in hell anybody, thing, or bolt is breaking it. I've used it to pop off rusted shut bolts (actually tearing the bolt) like they were made out of chocolate. I think you can get it a plumbing supply store (don't quote me on this). I'll ask where he got it next time I see him.
Old Oct 16, 2001 | 11:05 AM
  #30
DragII's Avatar
25 Year Member
Default Re: GD MF POS AXLE NUT!!!! (AshlandSi)
It's about 3 feet long, 1" thick (solid steel), has a non-ratcheting head, and 3/4" drive. There's no way in hell anybody, thing, or bolt is breaking it. .
hehe that's what I was using, only 1/2 inch...and yes, I am superman
Old Oct 16, 2001 | 03:20 PM
  #31
Kamin's Avatar
haha the enforcer.
comeon drag you can do it! soak the bitch in penetrating old and WD40 for a day or so.
[Modified by KAMiN, 12:20 AM 10/17/2001]
Old Oct 16, 2001 | 04:33 PM
  #32
Polo92gsr's Avatar
Default Re: GD MF POS AXLE NUT!!!! (KAMiN)
I know exactly what you mean bro. By the way did you run down to your local acura shop and buy a replacement nut because I know for sure that your gonna need a replacement if all else fails. I would hold off a bit, more of a last resort, using that torch thingy. I know its tempting but, man think of all the heat your transfering to everything....nope. I would by a replacement at least 1/2 in. breaker bar. You mentioned it was soaking so intstead of lossening the nut try to break it loose by tightening it first. I have had good experience with this ONE. You'll hear it break loose or turn a bit. Not much just enough to move it. Then back it out. I will mention I had an old honda accord once that I could have sworn someone welded it on just to make sure. What I did was remove the wheel and supported it with jackstands and then I chiseled the area that extends from the nut that acts like a cotter pin once you have it torqued and once I removed that area I was able to break the nut loose by chiseling on it for a bit. I believe there around 5 bucks or so to replace. I really hope this helps. Ohh, by the way, I almost always use a jack handle over my breaker bars for extra leverage also. Good Luck!
Old Oct 17, 2001 | 10:22 AM
  #33
Johnny62's Avatar
New User
2 and counting
"Jesus man, you either must be Superman or you're using some bitch-*** breaker bars. My neighbor has a bar we call the enforcer...."
That's funny as hell man, "The Enforcer". My buddies and I had a bad *** steel pipe that was about 4' long that we used for EVERYTHING. We called it "Pipe Dreams". When you slip that **** over a wrench ain't nothin' stopping it! Hell, we even used it to carry an engine around buy using a seatbelt as a strap and one guy on each side of the pipe to lift.
God Bless big *** pipes
[Modified by Johnny62, 11:23 AM 10/17/2001]
Old Oct 17, 2001 | 10:42 AM
  #34
allmotorEG-SI's Avatar
Default Re: GD MF POS AXLE NUT!!!! (Johnny62)
you could always... buy a new car.
redm3turbo
Mar 11, 2012 06:29 PM
SLeePeR-STaTuS
19
May 15, 2007 01:14 PM
neogenesis2004
May 4, 2004 11:06 AM
wm5holla
52
Sep 5, 2003 06:23 AM
6.5inCivic
33
Aug 6, 2002 11:45 AM
