G tech pro
I know gtech times and track times are no where the same. I was playing with my buddys gtech the other day and since the local track is closed for the year I was wondering what people have ran on a gtech and then at the track. Also what was your gtec trap speed. I was running 13.7-13.9 @ 107-109.7.
yeah i heard tracks use an average of speeds XX feet before the finish line and XX feet after the finish ...
and then Gtech finds it at exactly the 1/4 ... im not sure how truthful it all is...
but maybe thats where they get "trap" speed from the trap before and after the finish line ????
the Gtechs acurracy is directly linked to the installation accuracy, if you stick it level and pointing exactly forward it will give you a very accurate reading, if you start the 1/4 on a roll ofcourse the reading will be less accurate, you should take off 2-3mph from your trap speed as Gtech measures only at 1320ft, whereas the tracks averages your speed over the last 60ft of the 1320.
geminis2k
Aug 11, 2003 12:40 PM
