G tech pro
Old Dec 15, 2001 | 07:04 PM
hybrid901's Avatar
Default G tech pro
I know gtech times and track times are no where the same. I was playing with my buddys gtech the other day and since the local track is closed for the year I was wondering what people have ran on a gtech and then at the track. Also what was your gtec trap speed. I was running 13.7-13.9 @ 107-109.7.
Old Dec 15, 2001 | 08:52 PM
89civic1.8T's Avatar
Default Re: G tech pro (hybrid901)
My Best GTech time
14.0 @ 110
best tack
14.032 @ 104.85
MPH is higher because tracks use a trap to get your speed at the end G-Tech is instantanoius.
Old Dec 15, 2001 | 09:06 PM
l's Avatar
l
yeah i heard tracks use an average of speeds XX feet before the finish line and XX feet after the finish ...
and then Gtech finds it at exactly the 1/4 ... im not sure how truthful it all is...
but maybe thats where they get "trap" speed from the trap before and after the finish line ????
Old Dec 16, 2001 | 12:19 AM
Mista Bone's Avatar
D Tranny Guru
My best GTECH time was 13.9 @ 110+ mph.
Timeslip said 15.57 @ 87.
GTECH SUX
Old Dec 16, 2001 | 12:25 AM
hybrider's Avatar
Default Re: G tech pro (Mista Bone)
lol
Old Dec 16, 2001 | 04:10 PM
TheX-Man's Avatar
gtech 15.3 @ 93
track 15.6 @ 89
Old Dec 16, 2001 | 06:30 PM
ezark's Avatar
Default Re: G tech pro (TheX-Man)
Gtech is great to compare mods for yourself. Also, from what i've experienced, the street has better traction- therefore making the 1/4 a tad quicker.
Old Dec 17, 2001 | 05:57 AM
rtype11's Avatar
Default Re: G tech pro (krazE)
the Gtechs acurracy is directly linked to the installation accuracy, if you stick it level and pointing exactly forward it will give you a very accurate reading, if you start the 1/4 on a roll ofcourse the reading will be less accurate, you should take off 2-3mph from your trap speed as Gtech measures only at 1320ft, whereas the tracks averages your speed over the last 60ft of the 1320.
Old Dec 17, 2001 | 11:47 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: G tech pro (rtype11)
In my case, ut was the slicks I was using at the track. The HARD launch fools the GTECH.
Yes I did zero it out after burnout/before staging
JFK78
Jul 1, 2010 11:29 AM
98h22
Jun 21, 2009 01:34 PM
geminis2k
Aug 11, 2003 12:40 PM
HaTcH_BmX
Jul 18, 2003 03:34 PM
DIRep972
Jun 12, 2003 08:24 PM
