Fuse/Relay to Distibutor
Old Jan 21, 2017 | 08:00 AM
billabongrob's Avatar
Default Fuse/Relay to Distibutor
Without going into too many details, wiring from scratch for a race car. Trying to put the power to the distributor on a relay/switch combo. If I were to fuse this, what size fuse would I need? Looking over the manuals, there's a 50 amp on the blk/yellow going to the distributor system, but it's shared among other things. Any input is greatly appreciated!
92 integra, OBD1
Old Jan 21, 2017 | 09:50 AM
solomon93's Avatar
Default Re: Fuse/Relay to Distibutor
What size does the wire look like feeding power to the distributor? I'm sure its only 16 gauge. I would use an inline ATC 20A or smaller. Anything bigger and the wire becomes the fuse and bad things happen.
Old Jan 21, 2017 | 10:59 AM
Not 100% on that. Looks like the same as the actuator on the starter. Maybe 10g? Has a thin little blue with it which I believe is rpm though I could be wrong.
Old Jan 21, 2017 | 08:07 PM
solomon93's Avatar
Trust me it's not 10 gauge that's what most household dryer outlets are wired with. Use a pair of wire strippers and figure it out.
Old Jan 22, 2017 | 07:34 AM
The wires referenced on this site http://www.civic-eg.com/causeforalar...onnector_4.jpg mention 10g Butt connectors for the wiring.
It's the same size that comes off of the ignition switch.
Old Jan 28, 2017 | 06:23 PM
Bump?
latino honda
May 24, 2019 11:32 AM
TooManyHobbies
Sep 22, 2014 05:12 PM
Jason Combs
43
Jan 17, 2014 01:48 PM
vtekthis
Jun 22, 2006 02:31 PM
BigDaddyRich
Apr 9, 2005 08:31 AM
