B18C1 piston boring
Old Apr 21, 2007 | 11:26 PM
Honda-Power's Avatar
Default B18C1 piston boring
I have a b18c1 motor, and im trying to figure out what is the biggest bore size that i can do (including rebuilding and sheeving the motor to accommodate the new bore size), i can do with a b18c block without risking having the motor overheating to much or making the block to thin so that it would crack. any ideas?
Modified by Honda-Power at 9:37 PM 4/22/2007
Old Apr 22, 2007 | 04:13 AM
NJIN BUILDR's Avatar
Default Re: B18C1 piston boring (Honda-Power)
The biggest safe bore on stock sleeves is 82mm (+1mm or +.040").
Old Apr 22, 2007 | 08:28 AM
gibsanez's Avatar
Default Re: B18C1 piston boring (NJIN BUILDR)
with a sleeved motor you can go to 84 and sometimes bigger, but depends on how much you want to risk
Old Apr 24, 2007 | 03:52 PM
Lubo_25's Avatar
Default Re: B18C1 piston boring (gibsanez)
ill be doing a 89mm bore f23a block with dartons...the machine work is everything! i cant stress that enough...
Old Apr 25, 2007 | 02:35 PM
DonF's Avatar
Default Re: B18C1 piston boring (Lubo_25)
And that has WHAT to do with his B-series motor.
Old Apr 25, 2007 | 03:11 PM
slomofo's Avatar
GDD Member
I've seen as big as 87mm on an n/a B18C1. I currently have 84.5mm in my Turbo B18C1.
This link below shows a 2.2L kit for the b-series:
http://www.accountwizard.com/c...d=368
It doesn't list the detailed specs on the link I provided, but I know that eagle's longest stroked B-Series crank is 92mm, so the bore would have to be 87mm or 87.5mm to achieve a 2186cc or 2212cc displacement which translates to 2.2L.
Obviously you'd have to resleeve to do this.
Old Apr 25, 2007 | 03:28 PM
von_clutch's Avatar
i checked the post search already, i jus wanna knw if anyone has any links to what exactly is the purpose of sleeving, how is it achieved, what are its cons? im currently bulding an ls/vtec to drop in a gen2 tegs...oh plus i wanna go turbo...so how wud it help?
Old Apr 26, 2007 | 01:14 PM
Lubo_25's Avatar
Default Re: B18C1 piston boring (DonF)
it means smartass...that whoever is doing his machine work better ****** well know that these are not chevy motors...you can run any bore up to 85mm on your b series just find the right shop
Old Apr 26, 2007 | 06:24 PM
gibsanez's Avatar
anyone else read the article in honda-tuning about the webbing of the mains "relaxing" once the sleeves are taken out, and how they go even more out of whack when the new ones are pressed in?
Old Apr 26, 2007 | 07:05 PM
all-mtr-teg's Avatar
you can bore a stock b18 up to 85mm and not destroy your motor?
Old Apr 27, 2007 | 07:23 AM
gibsanez's Avatar
Default Re: B18C1 piston boring (all-mtr-teg)
not without sleeving
Old Apr 27, 2007 | 08:31 AM
sauceja's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">you can bore a stock b18 up to 85mm and not destroy your motor?</TD></TR></TABLE>
Maybe all-motor but that would be pushing thin.
Old Apr 27, 2007 | 09:12 PM
Default Re: B18C1 piston boring (sauceja)
even with high compression? 12.1:1?
Old Apr 28, 2007 | 05:53 PM
Lubo_25's Avatar
with darton sleeves 85mm is max. bore thats usually reserved for race motors 84mm is the safe zone for a street bore and can easily take 12+ compression without worries...proven time and time again with dartons mids...
Old Apr 28, 2007 | 09:33 PM
slomofo's Avatar
GDD Member
87mm max
already been posted
/thread.
Old Apr 29, 2007 | 09:54 PM
doood's Avatar
been there done that
Default Re: (slomofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by von_clutch &raquo;</TD></TR><TR><TD CLASS="quote">i checked the post search already, i jus wanna knw if anyone has any links to what exactly is the purpose of sleeving, how is it achieved, what are its cons? im currently bulding an ls/vtec to drop in a gen2 tegs...oh plus i wanna go turbo...so how wud it help?</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=565375
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">anyone else read the article in honda-tuning about the webbing of the mains "relaxing" once the sleeves are taken out, and how they go even more out of whack when the new ones are pressed in?</TD></TR></TABLE>
i did. i've also read things on here from earl and a few other sleeving company's saying otherwise when sleeved correctly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo &raquo;</TD></TR><TR><TD CLASS="quote">87mm max
already been posted
/thread.</TD></TR></TABLE>
for a race engine. biggest i would go for a street engine is 84-85mm.
clint g
Jun 26, 2005 10:37 AM
vteczone
Nov 9, 2003 04:25 PM
Quik Chris
Dec 21, 2002 10:11 AM
Ruby Civic
Dec 18, 2002 06:43 PM
integra-modder
Nov 3, 2002 05:12 PM
