Fuel pump to flow water? possible problems?
Old Feb 25, 2004 | 08:11 PM
Sinner's Avatar
Default Fuel pump to flow water? possible problems?
I want to use my S/DX fuel pump to flow water to my liquid intercooler. What are the cons about doing this?
Nick
Old Feb 25, 2004 | 08:51 PM
N2O's Avatar
N2O
Default Re: Fuel pump to flow water? possible problems? (Sinner)
The pressure that it flows is not that big of a deal. I am not sure that it will flow enough volume of water. We are running a Jabsco pump that puts out up to 5 gallons a minute. Just make sure that you are moving the water fast or it will do no good. Try to find out the GPM of your pump and make sure the inlet and out let is large enough to handle all the water.
Good Luck
Old Feb 25, 2004 | 09:05 PM
MBenzTek134's Avatar
Default Re: Fuel pump to flow water? possible problems? (N2O)
maybe im wrong but wont a fuel pump that is converted into a water pump eventually build up a lot of corrosion and cause problems?
Old Feb 25, 2004 | 09:21 PM
N2O's Avatar
N2O
Default Re: Fuel pump to flow water? possible problems? (MBenzTek134)
I did not think about that but you could be right
Joshua Coulson
Feb 11, 2016 11:45 AM
nasteawhun
11
Jul 21, 2008 02:19 PM
mattcivic
Jun 21, 2005 10:07 PM
808State
Apr 8, 2004 12:22 AM
