Fuel Pressure too high!HELP!
Old Sep 16, 2004 | 10:13 AM
hybrid_vtec's Avatar
Default Fuel Pressure too high!HELP!
Ever since upgrade from my stock 92 Si Fuel pump to a 255lph Walboro unit my fuel pressure has been dangerously high(55-60psi at idle) and my FPR will not bring it down any lower! I have also tried the FPR trick on the Endyne website to help relieve more pressure from the system, still staying strong between 55-60 psi! So I am wondering:
1. Should I go back to the stock OEM fuel pump?
2.What size fuel pump is the OEM unit for a 92-95 Civic Si HB(D16Z6 original motor)?
Here is my setup if this helps:
EG Civic HB
B18A Block/ B18B Head
-Mild PnP
-Crower 404 w/ JG Cam Gears
-Crower Valvesprings
-Ferrea SS Valves
-Cometic Head Gasket
-Skunk2 Mani
-64mm TB
-Modified Iceman intake
-JDM ITR 4-1 header w/ 2.5" collector
-No Cat
-2.5" custom piping and exhaust
-P30 B16 Pistons
-Stock Rods
-GSR Tranny w/ LSD
-Exedy Flywheel
-Clutch Specialties 6-puck clutch
-H22 injectors
-Walboro 255lph fuel pump
-SAFC2
-Chipped P75
Old Sep 16, 2004 | 10:30 AM
StyleTEG's Avatar
Default Re: Fuel Pressure too high!HELP! (hybrid_vtec)
http://www.theoldone.com/articles/regulator/
This should solve your problems.
Old Sep 16, 2004 | 10:32 AM
Default Re: Fuel Pressure too high!HELP! (StyleTEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StyleTEG &raquo;</TD></TR><TR><TD CLASS="quote">http://www.theoldone.com/articles/regulator/
This should solve your problems.</TD></TR></TABLE>
I already did that and it did nothing! Still sits at 60psi at idle!
Old Sep 16, 2004 | 10:35 AM
StyleTEG's Avatar
Try opening the hole larger then.
Old Sep 16, 2004 | 11:24 AM
Wondering if I should or not! Do not want to damage the FPR!
Old Sep 16, 2004 | 03:20 PM
kwoksturr's Avatar
try gettin the B&M fuel pressure modifier.
Old Sep 16, 2004 | 04:12 PM
eda6's Avatar
Default Re: Fuel Pressure too high!HELP! (kwoksturr)
Is the fuel return line kinked?
What the pressure if the hose is off the fpr?
Needle in the gage stuck?
If you removed the B&M top part before drilling, did you reinstall the o-ring correctly?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StyleTEG &raquo;</TD></TR><TR><TD CLASS="quote">Try opening the hole larger then.</TD></TR></TABLE> Don't do it
I think the problem is in the fpr. Even with a stock fpr the pressure won't be that high.
I'm just shooting out possibilities. Keep us posted.
Old Sep 16, 2004 | 07:12 PM
StyleTEG's Avatar
Default Re: Fuel Pressure too high!HELP! (eda6 hb)
He is running a high fuel pressure pump, and he is using a FPR that can not lower FP only increase it.
Of cource its going to be higher than stock
A larger hole is just going to alow more pressure to be bled off.
Old Sep 16, 2004 | 08:53 PM
rev-speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StyleTEG &raquo;</TD></TR><TR><TD CLASS="quote">He is running a high fuel pressure pump, and he is using a FPR that can not lower FP only increase it.
A larger hole is just going to alow more pressure to be bled off.</TD></TR></TABLE>
said it before i can!
i had this problem before
sell that pump and get the other or try a real fuel pressure regulator
Old Sep 16, 2004 | 09:03 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StyleTEG &raquo;</TD></TR><TR><TD CLASS="quote">he is using a FPR that can not lower FP only increase it. </TD></TR></TABLE>
What fpr is being used?
Old Sep 16, 2004 | 09:08 PM
rev-speed's Avatar
one like a cheap b&m
thats why he tried to mod
(drilling a hole to bleed off pressure)
but when u make the hole too big u lose flow and by then u have damage the fpr
Old Sep 16, 2004 | 09:43 PM
eda6's Avatar
Default Re: Fuel Pressure too high!HELP! (4cylinder)
That's what I thought. I drilled a .032" hole in my fpr with adj b&m. I run 50 psi (hose off)/ 40 psi (hose on). I run a walbro 255 w/no problem. I still think the problem is in the fpr.
Old Sep 17, 2004 | 06:08 AM
Well I put the stock Fuel pump back in lastnigh and my fuel pressure went down to 20psi. So I turned it up and highest it would go was 40 with the hose off and it sits at 36 with the hose on! I think where I modded the FPR now it will not hold high pressure!
Old Sep 17, 2004 | 09:29 AM
TECH43 RACING INC.'s Avatar
you need a fpr with a big return orifice (aem, aeromotive, sx, etc) the b&m (stock) cannot return enough fuel, and this is causing too much pressure at the rail. my opinion? buy a aem regulator.
hint for everyone else running naturally aspirated: stop buying 255 lph pumps, its way overkill. the 190lph will support more horsepower than you will ever, ever be able to make.
Old Sep 17, 2004 | 09:56 AM
Default Re: Fuel Pressure too high!HELP! (TECH43 RACING INC.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TECH43 RACING INC. &raquo;</TD></TR><TR><TD CLASS="quote">
hint for everyone else running naturally aspirated: stop buying 255 lph pumps, its way overkill. the 190lph will support more horsepower than you will ever, ever be able to make.</TD></TR></TABLE>
I know this now! I was told to run the 255lph when I was spraying my old motor!
What size is the OEM Fuel Pump?
Thanx
Old Sep 17, 2004 | 10:01 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec &raquo;</TD></TR><TR><TD CLASS="quote">
Thanx </TD></TR></TABLE>
not sure on flow rates, call john @ rc, he'll know. 310-320-2277. i know the oem pumps can support appx 210 whp. go ahead and use the 255 since you've got it, get the aem regulator. it will fix all your problems.
Old Sep 20, 2004 | 10:04 AM
not sure on flow rates, call john @ rc, he'll know. 310-320-2277. i know the oem pumps can support appx 210 whp. go ahead and use the 255 since you've got it, get the aem regulator. it will fix all your problems.</TD></TR></TABLE>
Thanx! Im using the stock pump again until I get an AEM FPR!
I wonder if an OEM pump will support H22 injectors
Old Sep 21, 2004 | 11:20 AM
those injectors wont work well without a hondata.
try stock injectors, should be fine.
Old Sep 21, 2004 | 01:08 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TECH43 RACING INC. &raquo;</TD></TR><TR><TD CLASS="quote">those injectors wont work well without a hondata.
try stock injectors, should be fine.</TD></TR></TABLE>
What about an SAFC2!
Old Sep 21, 2004 | 02:22 PM
not enough adjustablilty, trust me, put in the 240's, they are MORE than sufficient for your setup. they can support 210+ whp.
Old Sep 22, 2004 | 05:24 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TECH43 RACING INC. &raquo;</TD></TR><TR><TD CLASS="quote">not enough adjustablilty, trust me, put in the 240's, they are MORE than sufficient for your setup. they can support 210+ whp.</TD></TR></TABLE>
Thanx for the info!
Old Sep 22, 2004 | 10:23 AM
builthatch's Avatar
MiG-21 superfan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TECH43 RACING INC. &raquo;</TD></TR><TR><TD CLASS="quote">go ahead and use the 255 since you've got it, get the aem regulator. it will fix all your problems.</TD></TR></TABLE>
this is correct, this is what i have-
Old Sep 22, 2004 | 10:29 AM
builthatch's Avatar
MiG-21 superfan
also correct; keep in mind that JUN only offers an injector upgrade for their stage 4 engine packages to approx. a 270cc injector...this is approx. a 200 wheel hp setup.
Vtec-Mike
Jan 7, 2006 10:02 AM
hondaeg8
12
Oct 15, 2004 06:25 AM
speedymon
Nov 10, 2003 04:50 AM
Lei Siew Long
Jan 19, 2002 03:45 PM
