fuel pressure question
Old Sep 8, 2005 | 01:43 PM
Bartman201's Avatar
Default fuel pressure question
What is the stock fuel pressure for a 98 Integra LS?
Old Sep 8, 2005 | 02:02 PM
crush's Avatar
Default Re: fuel pressure question (Bartman201)
stocj fuel pressure is 28 i think
Old Sep 8, 2005 | 04:03 PM
Bartman201's Avatar
Default Re: fuel pressure question (crush)
ok right now is at 42, i was running 100 of NOS, but i took it out cause im going turbo. so far i change the pistons to 9:1, fuel press reg, headers, cam gears, fuel pump, port and pol the head. what should my fuel press be at right now with out the turbo just with the mods that i got..
Old Sep 8, 2005 | 08:45 PM
Bartman201's Avatar
come on. someone give me a hand
Old Sep 8, 2005 | 09:02 PM
Bartman201's Avatar
ttt
Old Sep 8, 2005 | 09:17 PM
rev-speed's Avatar
honda/acura 88-00
is 35 with vaccum
and 43 psi no vaccum
but its 40-50 psi when u check it
Old Sep 8, 2005 | 09:20 PM
Bartman201's Avatar
Default Re: (rev-speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rev-speed &raquo;</TD></TR><TR><TD CLASS="quote">honda/acura 88-00
is 35 with vaccum
yes its like 43 or 45 with vaccum
the reason that i want to know its because my car in not passing the state inspection cause its burning too much gas or something like that..
Old Sep 8, 2005 | 09:42 PM
rev-speed's Avatar
post ur smog inspection paper(vir)
Old Sep 8, 2005 | 09:45 PM
Bartman201's Avatar
in this forum or a diff one, also i live in mass, not cali
Old Sep 8, 2005 | 11:05 PM
Bartman201's Avatar
Default Re: (Bartman201)
ttt
Old Sep 12, 2005 | 10:52 PM
rev-speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bartman201 &raquo;</TD></TR><TR><TD CLASS="quote">in this forum or a diff one, also i live in mass, not cali</TD></TR></TABLE>
in this forum
doesn t matter where ur at
the smog sheet will tell a great smog tec how ur cars runing and what area to look at
Old Sep 13, 2005 | 07:00 AM
mmuller's Avatar
Mad Scientist
what fuel pump are you using?
are you using the stock fpr? pressure seems stock
Old Sep 13, 2005 | 07:37 AM
Bartman201's Avatar
Default Re: fuel pressure question (mmuller)
fuel pump is a holley fuel pump.
the fuel pressure reg is a cheap one. im going to get a better one, i think that my FPR is f up.
Old Sep 13, 2005 | 08:12 AM
mmuller's Avatar
Mad Scientist
it could be; whats the fuel pump specs?
it could be putting out too much for the lil cheap regulator to handle.
Old Sep 13, 2005 | 09:44 AM
Bartman201's Avatar
the Fuel Pres reg is a B&M cheap peace of Shhhhhh
the fuel pump is a Holley Acura Integra fuel pump provides 255 LPH. High flow in tank design is a direct replacement for the stock Integra fuel pump. The Holley Integra fuel pump features a Geroter design, rated for continuous duty, silent operation. The Holley Acura Integra fuel pump flows 67 gallons per hour, 404 lbs. of fuel, and will feed up to 800 horsepower.
Old Sep 13, 2005 | 02:55 PM
Bartman201's Avatar
ttt
Old Sep 13, 2005 | 10:17 PM
Bartman201's Avatar
siblue_gzer
Oct 11, 2006 07:38 AM
gsrboost
Mar 7, 2005 12:24 PM
BoOsTiN Dc2
Feb 1, 2005 10:05 AM
Propulsion
Nov 24, 2003 09:38 AM
DR. ON POINT
Apr 4, 2002 02:07 PM
