Fuel Pressure Problem!!
Old Aug 24, 2004 | 10:01 AM
hybrid_vtec's Avatar
Default Fuel Pressure Problem!!
I have already searched and went to the endyne site and modified my FPR, but my Fuel Pressure still stay constant at 50psi at the lowest setting! It can be adjusted up and down, just not below 50 psi!
Anyone else have any ideas?
Old Aug 26, 2004 | 08:13 AM
Default Re: Fuel Pressure Problem!! (hybrid_vtec)
bump for help
Old Aug 26, 2004 | 08:48 AM
JimBlake's Avatar
Maybe you have some restriction in the fuel return line. The FPR works by putting back-pressure on the fuel return line. But if there's some OTHER blockage in the return line, the FPR is powerless to do anything about it.
Old Aug 26, 2004 | 10:07 AM
Default Re: Fuel Pressure Problem!! (JimBlake)
So how would I get what ever it is out of there or even check for it!
Old Aug 26, 2004 | 10:43 AM
{StatuS ChecK}'s Avatar
You should get an AEM unit, good quality.
What FPR do you have now.
Old Aug 26, 2004 | 10:45 AM
JimBlake's Avatar
I'm not sure, never happened to me, so I'm just thinking of silly ideas...
Take the return hose off of the FPR, blow compressed air into it?
Did you do any kind of work where maybe you pinched the return line when you reinstalled something?
I'm not even sure where the return line goes exactly. Underneath the car? Ever bottom out on a speedbump & crush it? Crush it with a jackstand??
Old Aug 26, 2004 | 11:40 AM
Default Re: Fuel Pressure Problem!! ({StatuS ChecK})
QUOTE={StatuS ChecK}]You should get an AEM unit, good quality.
What FPR do you have now.[/QUOTE]
B&M FPR is what I have![
Old Aug 26, 2004 | 11:48 AM
Well What EXACT fuel mods do you have (important) If you have a 200LPH fuel pump or higher. than The B&M gotta go. The output diamiter is to small to let the extra fuel out fast enough, cause the B&M units use stock internals.
I Dropped in a Walbro 255HP, and I had to swap my B&M for a standalone AEM unit.... Here is more INFO. : http://www.turbod16.com/viewtopic.php?t=10736
-Vote Kerry.
Old Aug 27, 2004 | 05:36 AM
thanx b/c thats exactly what I have as well as H22 injectors! AEM huh! Well anyone got one for sale?
Old Aug 27, 2004 | 09:25 AM
well you can try ebay or the classifieds.
Old Aug 27, 2004 | 10:02 AM
thanx again
turboef90
Aug 11, 2013 12:28 PM
polishedturd
54
Jun 5, 2008 02:00 PM
B16B_coupe
Jul 10, 2006 06:29 PM
baphomet
Oct 7, 2003 10:08 PM
IgniteTeg
May 29, 2002 11:08 PM
