fuel filter
Old Oct 28, 2007 | 05:24 PM
dirty nails's Avatar
Default fuel filter
I need instuctions on replacing the fuel filter on a 90 Accord.
Old Oct 29, 2007 | 05:12 AM
B16B_coupe's Avatar
HRD PKR
Default Re: fuel filter (dirty nails)
buy a helms manual
Old Oct 29, 2007 | 05:50 AM
hatchling37's Avatar
Default Re: fuel filter (B16B_coupe)
Place a shop towel under and around the fuel filter.
Fuel System Service Bolt
Relieve the fuel pressure.
Disconnect the battery negative cable from the battery.
Remove the fuel tank filler cap.
Use a box end wrench on the 6mm service bolt at the fuel pipe, while holding the special banjo bolt with another wrench.
Place a rag or shop towel over the 6mm service bolt.
SLOWLY loosen the 6mm service bolt one complete turn.
Remove the 12mm banjo bolt and the fuel feed pipe from the filter.
Fuel Filter Assembly
Remove the fuel filter clamp and the fuel filter.
Reverse procedure to install, use new washers as shown in illustration. CAUTION: Clean the flared joint of the high pressure hoses thoroughly before reconnecting them.
Torque the banjo bolt to 16 lb-ft (22 Nm) , torque fuel filter clamp bolt to 7 lb-ft (10 Nm) , torque high pressure fuel line to 27 lb-ft (38 Nm) .
But you should get a Helms if you plan on doing anymore DIY.
Old Oct 29, 2007 | 06:06 AM
civic121978's Avatar
make sure to use new crush washers on both sides of the line. You dont want any leaks. If you buy fuel filter from honda it will come with new washers. Not sure about after market. Good luck
Old Nov 4, 2007 | 03:20 AM
Default Re: fuel filter (hatchling37)
Great! I wasn't expecting such a thorough reply with pictures and everything. Yes, I'll get a Helms book I hadn't known about that.
magic hat #9
Jan 9, 2009 07:23 AM
zracer240
May 7, 2005 04:32 PM
cvc323
Jun 29, 2003 11:09 PM
Orig
Oct 28, 2002 05:09 AM
samdawgsol
May 13, 2002 09:40 AM
