fuel cell question
Old Jan 24, 2009 | 01:07 PM
2point1's Avatar
Default fuel cell question
Need help, I was planning on running a 10 gal. fuel cell w/ a GM sending unit which use's 0-90 ohm sender, and I want to use the factory fuel gauge but the problem is it use's 4-112 ohms, is there a way that I can use a resistor to up the ohms, so that I can use the factory fuel gauge? I know that the stock sender is 2-5 ohms full and 105-112 ohms empty, the thing is I don't know which way the GM sender work's as far as if the 0 ohm is the empty or full. Any advice will be greatly appreciated. Thanks
Old Jan 25, 2009 | 11:44 AM
2point1's Avatar
Default Re: fuel cell question
bump
Old Jan 25, 2009 | 02:54 PM
2point1's Avatar
some one please help
Old Jan 25, 2009 | 05:46 PM
fcm's Avatar
fcm
Old Fart
Why not just meter the output from the sending unit in the fuel cell so you know how it works.
Try connecting it to the stock gauge and see what it registers when float is at the bottom/middle/top. 94
Old Jan 25, 2009 | 09:29 PM
2point1's Avatar
bump
Old Jan 26, 2009 | 02:10 PM
2point1's Avatar
bump
Old Jan 26, 2009 | 07:07 PM
2point1's Avatar
bump
Old Jan 28, 2009 | 09:58 AM
2point1's Avatar
bump
Old Jan 28, 2009 | 10:42 AM
fcm's Avatar
fcm
Old Fart
Did you test the fuel sell sending unit? 94
818SpoonITR
Jun 22, 2011 12:05 AM
felon-k20
Jan 26, 2011 12:15 PM
SPOON_BeIgHtEeNsEe
Feb 20, 2009 01:01 PM
2point1
Jan 28, 2009 09:57 AM
mastarolla
Jan 10, 2004 10:06 PM
