A friggin code 68? WTF?
Old Apr 27, 2005 | 09:59 AM
B-B-K's Avatar
Default A friggin code 68? WTF?
I have an OBD0 PR3 chipped ECU running my first gen B16 in my 91 CRX. I get in my car today...start it up and I have a CEL. Car was running fine at idle. Pull the carpet back and I read a code 68. I read it like 9 times so Im sure it was a 68. I turn off the car, go pull my ECU fuse to reset the ECU then wait the 15 sec or whatever, put fuse back in and go to start the car and nothing....my battery light, oil light, and brake light go dim. Hmmm ok. Try to start it again and my main relay makes a nasty noise all lights go out and nothing happens. (lil ticked off and confused at this point) Try it again and she starts right up and I drive home.
Code 68? I did some searching and saw that there is no such thing in a Honda ECU. Maybe I missed something but I didnt even think OBD0 codes went that high.
So, main relay is going bad also?
Any ideas?
Matt
Old Apr 27, 2005 | 02:18 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: A friggin code 68? WTF? (B-B-K)
get a new main relay, and clean your wireharness ground at the thermostat, also check yolur engine grounds. hopefully your ecu isnt about to take a ****
Old Apr 27, 2005 | 04:13 PM
dfoxengr's Avatar
Default Re: A friggin code 68? WTF? (PURPLETERROR)
probably didnt count them right.
Old Apr 27, 2005 | 08:59 PM
B-B-K's Avatar
Default Re: A friggin code 68? WTF? (hybridvteceg)
I counted the 6 long lights followed by 8 short blinks. A couple times it also went into limp mode. One solid light. I would just shut if off and start it again and the limp would go away. I had a couple main relays sittin around and tried them both with the same outcome.
I came to conclusion it was the battery so I stole the battery out of my "racecar" and it starts now.
So Im guessin the battery just decided to give up? I dont know...I hate electrical ****.
Old May 12, 2005 | 08:17 AM
FunIntegras's Avatar
Solid ECU light could mean your ECU is Burned, Try another ECU
tylertocker
Oct 11, 2008 11:17 AM
innes887
Jun 7, 2007 08:16 AM
hyperB16Turbo
Oct 17, 2003 06:57 AM
Red_Si
Apr 29, 2003 10:27 AM
