FPR or fuel regulator??????
Old Jan 5, 2003 | 07:16 PM
WS6Dreams's Avatar
Default FPR or fuel regulator??????
Which one for my appilcation? ( I searched and searched, I got nothing)
'00 Civic Si
Skunk2 Intake manifold
Short ram intake
dc 4-2-1 headeR
random tech. cat
apexi n-1 cat back
vortech fuel rail
walbro 255 lph pump
I plan to go N/A and I thought a B&M FPR would be fine, but a buddy 'o mine at a local speed shop told me to get an aramotive(sp) fuel regulator. The fuel regulator is twice as much as the FPR. Which one would be the best way to go??
Thanks in advance
Old Jan 5, 2003 | 08:03 PM
sgT's Avatar
sgT
Default Re: FPR or fuel regulator?????? (BoTtLeFeDCRX)
FPR = fuel pressure regulator.
all cars have one stock.
if you want a cheap one, get the b&m. it works and it bolts on using the stock fpr.
the aeromotive one is nicer but is universal and doesnt bolt on.
I usually recommend the B&M or aem.
Old Jan 5, 2003 | 08:10 PM
RaceTilIDie's Avatar
Default Re: FPR or fuel regulator?????? (sgT)
Do you plan on using nitrous?
Old Jan 6, 2003 | 04:18 PM
WS6Dreams's Avatar
I'm sorry, I may have been misinformed but I thought FPR stood for Fuel Pressure Riser(the b&m one). I realize that I have one stock, I was just wondering which one would be better in the long run, after I do cams, vavletrain, and build the bottom end. Thanks
Old Jan 6, 2003 | 04:19 PM
WS6Dreams's Avatar
Default Re: FPR or fuel regulator?????? (RaceTilIDie)
Absolutly no nitrous
Old Jan 6, 2003 | 04:37 PM
sgT's Avatar
sgT
They are all the same as long as the quality is good and you have a guage to
read pressure with
Old Jan 6, 2003 | 04:44 PM
If you don't plan on using nitrous and staying N/A, the B&M one is fine and cheaper.
Old Jan 6, 2003 | 04:49 PM
WS6Dreams's Avatar
Ok that's what I thought. Thanks alot guys
Old Jan 6, 2003 | 04:57 PM
The adjustable FPR will let you go down to 20 PSI, which you don't need or want for N/A, and the diaphragms don't hold up well when using dry nitrous systems. So go with the B&M modifier.:
http://www.c-speedracing.com/howto/a...ustablefpr.php
SilverEK96
Mar 28, 2012 11:07 AM
danmej1
Nov 5, 2010 06:33 PM
qcktegls
Nov 16, 2004 07:42 PM
mengy007
Sep 2, 2004 11:38 AM
ATS*Mark
Jul 20, 2004 06:16 AM
