flywheel stuck?
Old Jul 5, 2003 | 05:08 PM
untitled's Avatar
Default flywheel stuck?
just playing. its not stuck but its becoming damn hard to get it off without power/air tools. the motor is outta the car. any hints?
Old Jul 5, 2003 | 07:58 PM
RyanEJ8's Avatar
Default Re: flywheel stuck? (88crx91integra)
Get air tools or a longer breaker bar are the only options. I had a bitch of a time with my crank pulley bolt. It sounds like you do alot of work on the engine if you've had the flywheel off a couple times, the air tools would be a worth while investment.
Old Jul 5, 2003 | 08:29 PM
speedsmith's Avatar
Default Re: flywheel stuck? (RyanCivic2000)
no crap, air tools are the way to go. if there is a home depot near by, you could get a good compressor, good impact gun, and if you want, an air wrench, and all necessary lines, fittings, etc. for about $500......
$500!!
how much would labor be on 1 engine R&R?
Old Jul 5, 2003 | 11:26 PM
blah13's Avatar
Default Re: flywheel stuck? (speedsmith)
Go to autozone or such and look for a "ring gear tooth holder" thats what its technically called. Theres a pic of it in the Helms manual for flywheel work. It locks the flywheel in place, then a breaker bar + small cheater pipe and it'll be cake.
Old Jul 7, 2003 | 09:35 AM
untitled's Avatar
Default Re: flywheel stuck? (blah13)
thanx
Old Jul 7, 2003 | 11:39 AM
SpyderZEX's Avatar
It also wouldn't hurt to spray a little "liquid wrench" on there too.... I sprayed some on mine and let it sit overnight. The next day, I simply used a rachet to loosen the bolts.....
Old Jul 7, 2003 | 05:06 PM
untitled's Avatar
Default Re: flywheel stuck? (SpyderZEX)
sprayed PB on it already.
Old Jul 7, 2003 | 07:32 PM
MaxSterling's Avatar
just stick a screwdriver into one of the flywheel hole and wedge in to the tranny.
Old Jul 8, 2003 | 01:08 AM
Vinceg99's Avatar
Default Re: flywheel stuck? (keith_phan)
This is what the Honda ring gear holder looks like and they arent cheap either over $100 bucks and most of the time they have to order them.
Old Jul 8, 2003 | 03:06 AM
97hb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keith_phan &raquo;</TD></TR><TR><TD CLASS="quote">just stick a screwdriver into one of the flywheel hole and wedge in to the tranny. </TD></TR></TABLE>
Thats what I did and it worked fine. Don't forget the threadlocker when reinstalling it.
Schultzie
Jan 16, 2008 09:41 AM
92integraVTECgsr
Apr 26, 2006 05:48 PM
mcgee*
Jul 1, 2005 07:59 PM
Ronin150
Feb 8, 2005 06:29 AM
Akira-R
Jul 29, 2001 04:43 AM
