fluctuating idle then dies ...problem when warm!!! HELP PLEASE!!!!
Old Jan 29, 2006 | 05:39 PM
esohsee's Avatar
Default fluctuating idle then dies ...problem when warm!!! HELP PLEASE!!!!
just installed a poormans type r and now having a weird idling issue.
it starts up fine and idles great till operating temp.
once warms up the idle surges then dies.
i took off the tps and no surges. i set the base idle and plugged it up, thought it was all good till i test drove it and it started to fluctuate again.
also i noticed the iacv is humming when i unplug it the humming stops. i been searching for days and nothing.
:LEASE DO NOT SAY IT'S THE FITV VALVE BECAUSE I DON'T HAVE ONE. THANKS::
Old Jan 29, 2006 | 08:44 PM
danerr's Avatar
Default Re: fluctuating idle then dies ...problem when warm!!! HELP PLEASE!!!! (esohsee)
id love to help but im not sure what you mean by poormans type r
Old Jan 30, 2006 | 05:14 AM
esohsee's Avatar
Default Re: fluctuating idle then dies ...problem when warm!!! HELP PLEASE!!!! (danerr)
poormans type r = b16 head gsr block
up for more help please!!
Old Jan 30, 2006 | 12:55 PM
Perfectionist's Avatar
When you set the base idle, was that with the IACV unplugged (should have been), or the TPS unplugged (should not have been)? Your post isn't clear.
Old Jan 30, 2006 | 05:26 PM
esohsee's Avatar
Default Re: fluctuating idle then dies ...problem when warm!!! HELP PLEASE!!!! (Perfectionist)
sorry... today i tried to set my base idle like the way helms says to. unplug iacv and let it idle (warm of course). before it could reach operating temp the rpm fluctuated and then died.started again then just did the same thing. for some reason when i unplug tps it'll idle fine, but it'll throw a code. then when it warmed up i tried to start it with the iacv unplugged. i started it and immediately died, i started it with my foot on the pedal and when i tried to idle it at 1000 it'll jump from 1000-1300. i had the idle screw back all the way out and still same results. hopefully this is much clearer thanks
Old Jan 30, 2006 | 07:02 PM
rainforest's Avatar
any cel's, look for what codes you have and go from there. when the car is wharmed up put your thumb over the port on the tb and feel for vacuume if the idle drops you need to replace the iacv. when wharmed up the iacv shouldent be sucking in extra air. also unplug the iacv if the idle doesent drop there is a problem in the iacv.
Old Jan 30, 2006 | 08:11 PM
esohsee's Avatar
Default Re: fluctuating idle then dies ...problem when warm!!! HELP PLEASE!!!! (rainforest)
no cel's. i know there is a hole in the tb and i didn't cover it completely but i know it sucks in air. i unplugged the iacv when warm and the engine just dies. i can't do a base idle either because when i have the iacv and start it it'll just die. when i start with little gas, the rpms goes up and down
Old Feb 1, 2006 | 07:12 AM
esohsee's Avatar
i adjusted the idle screw under the tb and the idle other screw. car idles now. but small jumps. probably need to get the tps calibrated but don't know how. oh well still good.
Old Feb 1, 2006 | 01:28 PM
d.str0y's Avatar
The tps and ignition timing can also affect the idle. Check to make sure the tps is at .45 volts at fully closed throttle. Set ignition timing to 16*. Then let the engine warm up and set the idle to about 650 rpms with the IACV unplugged. Then shut the car down, plug in IACV and reset ECU. Start the car back up to let the ECU learn the newly adjusted settings.
Old Feb 1, 2006 | 08:03 PM
b16g1teg's Avatar
Also check for any vaccum leaks those do create jumpy idles.
b20eg9daddy
Oct 25, 2008 12:37 PM
EK Josh
29
Apr 11, 2005 11:05 AM
daddymaxx
Dec 15, 2003 12:24 PM
