Fluctuating idle HELP!!
Old Feb 9, 2004 | 06:39 PM
HybriDNA's Avatar
Default Fluctuating idle HELP!!
Ok.. I just swapped in a LS/vtec motor that i built into my eg. Runs great. But when i bought the head the tps on the TB was cracked so i just glued the pieces back together... but i would think since all the prongs are still intact it would work the same. Well come to find out when i press the gas and hold it at 1,600 rpm's the rpm's starts to fluctuate ,uuuuup, dowwwwwwn,uuuuuup, dowwwwwn.. but if i press the gas past 1,600rpms it goes away and revs normal. IT DOES NOT FLUCTUATE AT IDLE. Do i have symptoms of a bad TPS or IAVC? I took off the IAVC and cleaned it.. and still have fluctuating
Old Feb 10, 2004 | 05:20 AM
EE_Chris's Avatar
Default Re: Fluctuating idle HELP!! (HybriDNA)
Grab a multimeter and test the TPS output. With the key-on, engine off @ idle, the TPS should output ~.45. Now slowly rotate the TPS ensuring that the signal does not drop out.
Old Feb 10, 2004 | 04:09 PM
HybriDNA's Avatar
Default Re: Fluctuating idle HELP!! (EE_Chris)
alright ill do that.
Thorgs
Apr 20, 2008 09:31 AM
SWC
Apr 5, 2006 05:37 PM
turbotime
Oct 24, 2005 12:01 PM
Tronix102
Jan 14, 2005 08:09 AM
T-Mo
11
Sep 28, 2003 10:17 AM
